Elegoo Mars 3 Motherboard Replacement
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
Remove 6 screws.
12.5mm self tapping screws with 2.0mm hex socket head
Use a small flat-headed screwdriver, spudger, or similar to pry open the lid enough to be able to get a grip of it and pull straight back and then fold down.
Remove the connectors by pulling them straight out.
Use a spudger or similar tool (your finger nail works if you can get it there) to loosen the resin panel connector by flipping the dark gray part 90° down.
Pull the cable straight up.
Remove the three cable connectors in the bottom right corner by pulling them straight out.
Remove the two screws fastening the motherboard to the unit.
7.5mm self tapping screws with 2.0mm hex socket head
Bu adımda kullanılan alet:Tweezers$4.99
Use a pair of tweezers to get a grip on and remove the tape covering the touch screen connector.
Use a spudger or similar to unlock the connector by pushing the dark gray part to the right, away from the connector, both on the top and bottom.
Remove the cable by pulling it out of the connector to the right.
Bir başkası bu kılavuzu tamamladı.
