Ana içeriğe geç
Element GC-1020 Battery Replacement
Neye ihtiyacın var
  1. Element GC-1020 Battery  Replacement, Back Cover Replacement Guide: adım 1, 1 resimden 1.
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
  2. Element GC-1020 Battery  Replacement: adım 2, 1 resimden 1.
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
  3. Element GC-1020 Battery  Replacement, Battery: adım 3, 2 resimden 1. Element GC-1020 Battery  Replacement, Battery: adım 3, 2 resimden 2.
    • Then remove the battery from the device through soldering the black and red wires connected to the motherboard.
    • This replacement will require a soldering station.
    • To find out more on soldering refer to the Soldering and Desolder page to help you through this process.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lashaun Noel
591 İtibar
5 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 334
