Ana içeriğe geç
Ematic FunTab 2 Battery Replacement
Neye ihtiyacın var
    1. Ematic FunTab 2 Battery Replacement, Battery: adım 1, 2 resimden 1. Ematic FunTab 2 Battery Replacement, Battery: adım 1, 2 resimden 2.
      • Pry open the Ematic FunTab 2 using the plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. Ematic FunTab 2 Battery Replacement: adım 2, 1 resimden 1.
      • Remove tape from the LCD connector.
      FixBot'a Sor
      Yorum Ekle
    3. Ematic FunTab 2 Battery Replacement: adım 3, 2 resimden 1. Ematic FunTab 2 Battery Replacement: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Flip up the retaining tab (the black bar on the connector), then pull LCD connector with tweezers. Be careful not to damage the LCD connector.
      FixBot'a Sor
      Yorum Ekle
    4. Ematic FunTab 2 Battery Replacement: adım 4, 3 resimden 1. Ematic FunTab 2 Battery Replacement: adım 4, 3 resimden 2. Ematic FunTab 2 Battery Replacement: adım 4, 3 resimden 3.
      • Now remove battery by putting the spudger between the battery and the LCD display and prying apart.
      • Be careful when prying the battery from the display. Wiggle the spudger if necessary.
      FixBot'a Sor
      Yorum Ekle
    5. Ematic FunTab 2 Battery Replacement: adım 5, 1 resimden 1.
      • Remove tape from the yellow, red, and black wires connecting the battery to the LCD.
      FixBot'a Sor
      Yorum Ekle
    6. Ematic FunTab 2 Battery Replacement: adım 6, 3 resimden 1. Ematic FunTab 2 Battery Replacement: adım 6, 3 resimden 2. Ematic FunTab 2 Battery Replacement: adım 6, 3 resimden 3.
      FixBot'a Sor
      Yorum Ekle
    7. Ematic FunTab 2 Battery Replacement: adım 7, 1 resimden 1.
      • Now remove battery. The battery should still be pried from the LCD display, if not pry it again.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 42
Her zaman: 2,782
