Ana içeriğe geç
Ematic FunTab 2 Motherboard Replacement
Neye ihtiyacın var
    1. Ematic FunTab 2 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
      • Remove back of Ematic FunTab by using the plastic opening tool to pry the back open.
      FixBot'a Sor
      Yorum Ekle
    2. Ematic FunTab 2 Motherboard Replacement: adım 2, 3 resimden 1. Ematic FunTab 2 Motherboard Replacement: adım 2, 3 resimden 2. Ematic FunTab 2 Motherboard Replacement: adım 2, 3 resimden 3.
      • Next, you need to remove all connections to the motherboard and the device.
      • Start by first removing the tape from all the connections.
      • Be careful not to remove the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Ematic FunTab 2 Motherboard Replacement: adım 3, 3 resimden 1. Ematic FunTab 2 Motherboard Replacement: adım 3, 3 resimden 2. Ematic FunTab 2 Motherboard Replacement: adım 3, 3 resimden 3.
      • Remove LCD connector from the LCD.
      • Be sure to flip up the retaining tabs before pulling the LCD connector out. (It is the black tab on the connection port).
      FixBot'a Sor
      Yorum Ekle
    4. Ematic FunTab 2 Motherboard Replacement: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Remove camera connection from camera with tweezers.
      • Again, be sure to flip up the retaining tab before pulling the connector.
      FixBot'a Sor
      Yorum Ekle
    5. Ematic FunTab 2 Motherboard Replacement: adım 5, 1 resimden 1.
      • Remove speaker connection from speaker with tweezers.
      • Before pulling the speaker connection make sure the retaining tab is flipped up.
      FixBot'a Sor
      Yorum Ekle
    6. Ematic FunTab 2 Motherboard Replacement: adım 6, 3 resimden 1. Ematic FunTab 2 Motherboard Replacement: adım 6, 3 resimden 2. Ematic FunTab 2 Motherboard Replacement: adım 6, 3 resimden 3.
      • Remove wires:
      • Start by removing the black wire on each side.
      • Next, remove the WiFi antenna wire from the motherboard.
      • Finally, remove the yellow, red, and black wires.
      • To put the wires back in their correct locations you will need a soldering iron to solder the wire back in place. You will do this once the motherboard is replaced. Here is a guide on how to solder Lehimleme ve Lehim Sökme Bağlantıları Nasıl Yapılır
      FixBot'a Sor
      Yorum Ekle
    7. Ematic FunTab 2 Motherboard Replacement: adım 7, 3 resimden 1. Ematic FunTab 2 Motherboard Replacement: adım 7, 3 resimden 2. Ematic FunTab 2 Motherboard Replacement: adım 7, 3 resimden 3.
      • Unscrew all four screws on motherboard with the Phillip's head screwdriver.
      • All of the screws are the same size, and should all fit in either corresponding screw location.
      FixBot'a Sor
      Yorum Ekle
    8. Ematic FunTab 2 Motherboard Replacement: adım 8, 2 resimden 1. Ematic FunTab 2 Motherboard Replacement: adım 8, 2 resimden 2.
      • It is now safe to remove and replace the old motherboard with your new motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 1,450
