Ana içeriğe geç
Ematic FunTab 3 Battery Replacement
Neye ihtiyacın var
  1. Ematic FunTab 3 Battery Replacement, Back Panel: adım 1, 3 resimden 1. Ematic FunTab 3 Battery Replacement, Back Panel: adım 1, 3 resimden 2. Ematic FunTab 3 Battery Replacement, Back Panel: adım 1, 3 resimden 3.
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
    FixBot'a Sor
    Yorum Ekle
  2. Ematic FunTab 3 Battery Replacement: adım 2, 1 resimden 1.
    • Pull the back panel away from the screen.
    FixBot'a Sor
    Yorum Ekle
  3. Ematic FunTab 3 Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the black tape to reveal the wire ribbon connector.
    FixBot'a Sor
    Yorum Ekle
  4. Ematic FunTab 3 Battery Replacement: adım 4, 3 resimden 1. Ematic FunTab 3 Battery Replacement: adım 4, 3 resimden 2. Ematic FunTab 3 Battery Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Flip up the black retaining tab using the plastic opening tool.
    • Pull out the large wire ribbon that crosses over the battery.
    • You may need tweezers to pull out the wire ribbon.
    FixBot'a Sor
    Yorum Ekle
  5. Ematic FunTab 3 Battery Replacement: adım 5, 3 resimden 1. Ematic FunTab 3 Battery Replacement: adım 5, 3 resimden 2. Ematic FunTab 3 Battery Replacement: adım 5, 3 resimden 3.
    • Insert the plastic opening tool under the battery.
    • Using the plastic opening tool, pry up the battery.
    • There is tape on the back of the battery. Some more force may be required to separate the battery from the back of the display.
    FixBot'a Sor
    Yorum Ekle
  6. Ematic FunTab 3 Battery Replacement: adım 6, 2 resimden 1. Ematic FunTab 3 Battery Replacement: adım 6, 2 resimden 2.
    • Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
    • After the connections are desoldered, remove the battery.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Amanda Davis
581 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018 üyesi
UWT-CARDINAL-SU18S1G5
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 27
Her zaman: 985
