Ana içeriğe geç
Ematic FunTab 3 Motherboard Replacement
Neye ihtiyacın var
  1. Ematic FunTab 3 Motherboard Replacement, Back Panel: adım 1, 3 resimden 1. Ematic FunTab 3 Motherboard Replacement, Back Panel: adım 1, 3 resimden 2. Ematic FunTab 3 Motherboard Replacement, Back Panel: adım 1, 3 resimden 3.
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
    FixBot'a Sor
    Yorum Ekle
  2. Ematic FunTab 3 Motherboard Replacement: adım 2, 1 resimden 1.
    • Pull the back panel away from the screen.
    FixBot'a Sor
    Yorum Ekle
  3. Ematic FunTab 3 Motherboard Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the black tape to reveal the wire ribbon connector.
    FixBot'a Sor
    Yorum Ekle
  4. Ematic FunTab 3 Motherboard Replacement: adım 4, 3 resimden 1. Ematic FunTab 3 Motherboard Replacement: adım 4, 3 resimden 2. Ematic FunTab 3 Motherboard Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Flip up the black retaining tab using the plastic opening tool.
    • Pull out the large wire ribbon that crosses over the battery.
    • You may need tweezers to pull out the wire ribbon.
    FixBot'a Sor
    Yorum Ekle
  5. Ematic FunTab 3 Motherboard Replacement: adım 5, 3 resimden 1. Ematic FunTab 3 Motherboard Replacement: adım 5, 3 resimden 2. Ematic FunTab 3 Motherboard Replacement: adım 5, 3 resimden 3.
    • Insert the plastic opening tool under the battery.
    • Using the plastic opening tool, pry up the battery.
    • There is tape on the back of the battery. Some more force may be required to separate the battery from the back of the display.
    FixBot'a Sor
    Yorum Ekle
  6. Ematic FunTab 3 Motherboard Replacement: adım 6, 2 resimden 1. Ematic FunTab 3 Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
    • After the connections are desoldered, remove the battery.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
    FixBot'a Sor
    Yorum Ekle
  7. Ematic FunTab 3 Motherboard Replacement, Speaker: adım 7, 2 resimden 1. Ematic FunTab 3 Motherboard Replacement, Speaker: adım 7, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  8. Ematic FunTab 3 Motherboard Replacement: adım 8, 3 resimden 1. Ematic FunTab 3 Motherboard Replacement: adım 8, 3 resimden 2. Ematic FunTab 3 Motherboard Replacement: adım 8, 3 resimden 3.
    • After the connections are desoldered, remove the speaker by prying it up using a plastic opening tool.
    • There is glue on the back of the speaker. Some more force may be required.
    FixBot'a Sor
    Yorum Ekle
  9. Ematic FunTab 3 Motherboard Replacement, Camera: adım 9, 2 resimden 1. Ematic FunTab 3 Motherboard Replacement, Camera: adım 9, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  10. Ematic FunTab 3 Motherboard Replacement: adım 10, 1 resimden 1.
    • Use the plastic opening tool to flip up the black retaining tab.
    FixBot'a Sor
    Yorum Ekle
  11. Ematic FunTab 3 Motherboard Replacement: adım 11, 2 resimden 1. Ematic FunTab 3 Motherboard Replacement: adım 11, 2 resimden 2.
    • Pull out the wire ribbon connected to the camera.
    • The camera is held in place by glue, so extra force may be required.
    • Remove the camera from the device.
    FixBot'a Sor
    Yorum Ekle
  12. Ematic FunTab 3 Motherboard Replacement, Motherboard: adım 12, 1 resimden 1.
    • Remove the black tape to reveal the screen connector.
    FixBot'a Sor
    Yorum Ekle
  13. Ematic FunTab 3 Motherboard Replacement: adım 13, 2 resimden 1. Ematic FunTab 3 Motherboard Replacement: adım 13, 2 resimden 2.
    • Flip up the retaining tab using the plastic opening tool.
    • Pull out the screen wire ribbon to disconnect the screen and motherboard.
    FixBot'a Sor
    Yorum Ekle
  14. Ematic FunTab 3 Motherboard Replacement: adım 14, 2 resimden 1. Ematic FunTab 3 Motherboard Replacement: adım 14, 2 resimden 2.
    • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
    FixBot'a Sor
    Yorum Ekle
  15. Ematic FunTab 3 Motherboard Replacement: adım 15, 1 resimden 1.
    • It is now safe to remove and replace the old motherboard with your new motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Amanda Davis
581 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018 üyesi
UWT-CARDINAL-SU18S1G5
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 35
Her zaman: 619
