Ana içeriğe geç
Ematic FunTab 3 Motherboard Replacement
Neye ihtiyacın var
  1. Ematic FunTab 3 Motherboard Replacement, Back Panel: adım 1, 3 resimden 1. Ematic FunTab 3 Motherboard Replacement, Back Panel: adım 1, 3 resimden 2. Ematic FunTab 3 Motherboard Replacement, Back Panel: adım 1, 3 resimden 3.
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Motherboard Replacement: adım 2, 1 resimden 1.
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Motherboard Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the black tape to reveal the wire ribbon connector.
  4. Ematic FunTab 3 Motherboard Replacement: adım 4, 3 resimden 1. Ematic FunTab 3 Motherboard Replacement: adım 4, 3 resimden 2. Ematic FunTab 3 Motherboard Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Flip up the black retaining tab using the plastic opening tool.
    • Pull out the large wire ribbon that crosses over the battery.
    • You may need tweezers to pull out the wire ribbon.
  5. Ematic FunTab 3 Motherboard Replacement: adım 5, 3 resimden 1. Ematic FunTab 3 Motherboard Replacement: adım 5, 3 resimden 2. Ematic FunTab 3 Motherboard Replacement: adım 5, 3 resimden 3.
    • Insert the plastic opening tool under the battery.
    • Using the plastic opening tool, pry up the battery.
    • There is tape on the back of the battery. Some more force may be required to separate the battery from the back of the display.
  6. Ematic FunTab 3 Motherboard Replacement: adım 6, 2 resimden 1. Ematic FunTab 3 Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
    • After the connections are desoldered, remove the battery.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
  7. Ematic FunTab 3 Motherboard Replacement, Speaker: adım 7, 2 resimden 1. Ematic FunTab 3 Motherboard Replacement, Speaker: adım 7, 2 resimden 2.
  8. Ematic FunTab 3 Motherboard Replacement: adım 8, 3 resimden 1. Ematic FunTab 3 Motherboard Replacement: adım 8, 3 resimden 2. Ematic FunTab 3 Motherboard Replacement: adım 8, 3 resimden 3.
    • After the connections are desoldered, remove the speaker by prying it up using a plastic opening tool.
    • There is glue on the back of the speaker. Some more force may be required.
  9. Ematic FunTab 3 Motherboard Replacement, Camera: adım 9, 2 resimden 1. Ematic FunTab 3 Motherboard Replacement, Camera: adım 9, 2 resimden 2.
  10. Ematic FunTab 3 Motherboard Replacement: adım 10, 1 resimden 1.
    • Use the plastic opening tool to flip up the black retaining tab.
  11. Ematic FunTab 3 Motherboard Replacement: adım 11, 2 resimden 1. Ematic FunTab 3 Motherboard Replacement: adım 11, 2 resimden 2.
    • Pull out the wire ribbon connected to the camera.
    • The camera is held in place by glue, so extra force may be required.
    • Remove the camera from the device.
  12. Ematic FunTab 3 Motherboard Replacement, Motherboard: adım 12, 1 resimden 1.
    • Remove the black tape to reveal the screen connector.
  13. Ematic FunTab 3 Motherboard Replacement: adım 13, 2 resimden 1. Ematic FunTab 3 Motherboard Replacement: adım 13, 2 resimden 2.
    • Flip up the retaining tab using the plastic opening tool.
    • Pull out the screen wire ribbon to disconnect the screen and motherboard.
  14. Ematic FunTab 3 Motherboard Replacement: adım 14, 2 resimden 1. Ematic FunTab 3 Motherboard Replacement: adım 14, 2 resimden 2.
    • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
  15. Ematic FunTab 3 Motherboard Replacement: adım 15, 1 resimden 1.
    • It is now safe to remove and replace the old motherboard with your new motherboard.
Sonuç
Amanda Davis
581 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018 üyesi
UWT-CARDINAL-SU18S1G5
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 444
