Ana içeriğe geç
Ematic Genesis Button Replacement
Neye ihtiyacın var
  1. Ematic Genesis Button Replacement, Ematic Genesis Casing: adım 1, 3 resimden 1. Ematic Genesis Button Replacement, Ematic Genesis Casing: adım 1, 3 resimden 2. Ematic Genesis Button Replacement, Ematic Genesis Casing: adım 1, 3 resimden 3.
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
    FixBot'a Sor
    Yorum Ekle
  2. Ematic Genesis Button Replacement: adım 2, 3 resimden 1. Ematic Genesis Button Replacement: adım 2, 3 resimden 2. Ematic Genesis Button Replacement: adım 2, 3 resimden 3.
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
    FixBot'a Sor
    Yorum Ekle
  3. Ematic Genesis Button Replacement: adım 3, 1 resimden 1.
    • Remove back plate from screen plate and lay both down flat next to each other.
    FixBot'a Sor
    Yorum Ekle
  4. Ematic Genesis Button Replacement, Battery: adım 4, 3 resimden 1. Ematic Genesis Button Replacement, Battery: adım 4, 3 resimden 2. Ematic Genesis Button Replacement, Battery: adım 4, 3 resimden 3.
    • Lift up the two pieces of tape holding the copper plate and the connector ribbon to the battery. Gently hold or place away from the battery.
    FixBot'a Sor
    Yorum Ekle
  5. Ematic Genesis Button Replacement: adım 5, 3 resimden 1. Ematic Genesis Button Replacement: adım 5, 3 resimden 2. Ematic Genesis Button Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Plastic Cards
    $2.99
    • Using a plastic card, gently break the adhesive that holds the battery to the metal screen plate.
    • The battery is very bendable. Although it may not be working, there are still dangerous contents inside batteries.
    FixBot'a Sor
    Yorum Ekle
  6. Ematic Genesis Button Replacement: adım 6, 1 resimden 1.
    • If replacing the battery, disconnect the wires that connect the battery to the motherboard.
    • If not replacing the battery, do NOT disconnect the wires.
    • To reconnect the new battery, a soldering kit will be necessary. Use the iFixit soldering guide to gain further information on how to complete this step.
    • Lehimleme ve Lehim Sökme Bağlantıları Nasıl Yapılır
    FixBot'a Sor
    Yorum Ekle
  7. Ematic Genesis Button Replacement, Camera: adım 7, 2 resimden 1. Ematic Genesis Button Replacement, Camera: adım 7, 2 resimden 2.
    • Once the panels are separated, remove the tape holding down the ribbon connector that is connecting the camera to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. Ematic Genesis Button Replacement: adım 8, 2 resimden 1. Ematic Genesis Button Replacement: adım 8, 2 resimden 2.
    • Lift up the black lever of the connector that holds the camera ribbon in place.
    FixBot'a Sor
    Yorum Ekle
  9. Ematic Genesis Button Replacement: adım 9, 2 resimden 1. Ematic Genesis Button Replacement: adım 9, 2 resimden 2.
    • Gently pull the ribbon out of the connector and lift the camera out of the casing.
    • There is adhesive holding the camera in the case. Pull up strong enough to separate the camera from the casing without damaging the components.
    FixBot'a Sor
    Yorum Ekle
  10. Ematic Genesis Button Replacement, Button: adım 10, 3 resimden 1. Ematic Genesis Button Replacement, Button: adım 10, 3 resimden 2. Ematic Genesis Button Replacement, Button: adım 10, 3 resimden 3.
    • Once battery is removed, flip up the black lever of the connector that is holding the wide ribbon in place for the screen. Remove the ribbon from the connector.
    FixBot'a Sor
    Yorum Ekle
  11. Ematic Genesis Button Replacement: adım 11, 3 resimden 1. Ematic Genesis Button Replacement: adım 11, 3 resimden 2. Ematic Genesis Button Replacement: adım 11, 3 resimden 3.
    • Rotate the tablet 180 degrees and flip up the black lever of the connector holding the small, yellow ribbon. Remove ribbon from the connector.
    FixBot'a Sor
    Yorum Ekle
  12. Ematic Genesis Button Replacement: adım 12, 3 resimden 1. Ematic Genesis Button Replacement: adım 12, 3 resimden 2. Ematic Genesis Button Replacement: adım 12, 3 resimden 3.
    • Rotate the tablet 90 degrees and remove the three (3) 1.3 mm Phillips #00 screws that hold the motherboard in place.
    FixBot'a Sor
    Yorum Ekle
  13. Ematic Genesis Button Replacement: adım 13, 2 resimden 1. Ematic Genesis Button Replacement: adım 13, 2 resimden 2.
    • Lift up the tape that covers the speaker wires and holds the motherboard in place.
    • This picture does not show speaker wires attached. These do NOT have to be disconnected for this.
    • Be careful not to disconnect the speaker wires from the motherboard. Otherwise, they will need to be soldered back on.
    FixBot'a Sor
    Yorum Ekle
  14. Ematic Genesis Button Replacement: adım 14, 2 resimden 1. Ematic Genesis Button Replacement: adım 14, 2 resimden 2.
    • With the motherboard detached from the screen plate, there is now access to the electrical components under the motherboard and the mechanical button components on the back plate.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Justin Rohrman
745 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-3, Williams Spring 2015 Baylor, Team 4-3, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G3
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 32
Her zaman: 576
