Ana içeriğe geç
Ematic eGlide 4 Motherboard Replacement
Neye ihtiyacın var
  1. Ematic eGlide 4 Motherboard Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Remove the 4.6mm Phillips #00 screw at the base of the device.
  2. Ematic eGlide 4 Motherboard Replacement: adım 2, 1 resimden 1.
    • Slide the rear panel away from the base parallel to the screen.
  3. Ematic eGlide 4 Motherboard Replacement: adım 3, 2 resimden 1. Ematic eGlide 4 Motherboard Replacement: adım 3, 2 resimden 2.
    • Carefully remove the speakers from the rear panel.
    • Pull the speakers off of the rear panel.
  4. Ematic eGlide 4 Motherboard Replacement, Speaker: adım 4, 1 resimden 1.
  5. Ematic eGlide 4 Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Slide the grey ribbon wire connector clip away from the ribbon wire port on the motherboard using the pointed tip of a spudger.
    • You do not need to fully disconnect the ribbon wire clip from the ribbon wire port: the clip will stay attached in a loose fit.
    • Remove the gold ribbon wire from the ribbon wire port on the motherboard.
  6. Ematic eGlide 4 Motherboard Replacement: adım 6, 1 resimden 1.
    • Slide the grey ribbon wire connector clip away from the white ribbon wire port on the screen board using the pointed tip of a spudger.
    • Remove the ribbon wire from the ribbon wire port on the screen board.
  7. Ematic eGlide 4 Motherboard Replacement: adım 7, 1 resimden 1.
    • Slide the grey ribbon wire connector clip away from the ribbon wire port using the pointed tip of a spudger.
    • Remove the ribbon wire from the ribbon wire port.
    • If you have already removed the side button array you do not need to do this step.
  8. Ematic eGlide 4 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the 2 Phillips #00 4.5 mm screws from the motherboard.
  9. Ematic eGlide 4 Motherboard Replacement: adım 9, 1 resimden 1.
    • Desolder the Wi-Fi Adaptor
    • If not replacing the motherboard or Wi-Fi Adaptor, omit this step
    • See ifixit's guide to soldering and desoldering for help: How to Solder and Desolder Connections
  10. Ematic eGlide 4 Motherboard Replacement: adım 10, 1 resimden 1.
    • Desolder the battery connections
    • If not replacing the motherboard or battery, omit this step
  11. Ematic eGlide 4 Motherboard Replacement: adım 11, 2 resimden 1. Ematic eGlide 4 Motherboard Replacement: adım 11, 2 resimden 2.
    • Slide and pull the motherboard out of its current position, so that the ports disconnect from the device.
    • Lift the motherboard out of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bailey Hughes
617 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-8, Williams Spring 2015 Baylor, Team 5-8, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S5G8
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 302
