Ana içeriğe geç
Ematic eGlide 4 Wi-Fi Adaptor Replacement
Neye ihtiyacın var
  1. Ematic eGlide 4 Wi-Fi Adaptor Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Remove the 4.6mm Phillips #00 screw at the base of the device.
  2. Ematic eGlide 4 Wi-Fi Adaptor Replacement: adım 2, 1 resimden 1.
    • Slide the rear panel away from the base parallel to the screen.
  3. Ematic eGlide 4 Wi-Fi Adaptor Replacement: adım 3, 2 resimden 1. Ematic eGlide 4 Wi-Fi Adaptor Replacement: adım 3, 2 resimden 2.
    • Carefully remove the speakers from the rear panel.
    • Pull the speakers off of the rear panel.
  4. Ematic eGlide 4 Wi-Fi Adaptor Replacement, Wi-Fi Adaptor: adım 4, 1 resimden 1.
  5. Ematic eGlide 4 Wi-Fi Adaptor Replacement: adım 5, 1 resimden 1.
    • Gently pry the antenna out of the front case
Sonuç
Bailey Hughes
617 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team 5-8, Williams Spring 2015 Baylor, Team 5-8, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S5G8
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 125
