Ana içeriğe geç
Emerson EM744 Battery Replacement
Neye ihtiyacın var
    1. Emerson EM744 Battery  Replacement, Back Plate: adım 1, 1 resimden 1.
      • Use a Phillips 00 bit to remove two 3mm screws from the bottom of the tablet.
      FixBot'a Sor
      Yorum Ekle
    2. Emerson EM744 Battery  Replacement: adım 2, 3 resimden 1. Emerson EM744 Battery  Replacement: adım 2, 3 resimden 2. Emerson EM744 Battery  Replacement: adım 2, 3 resimden 3.
      • Insert the nylon spudger into the bottom of the tablet, and gently slide it up the side.
      • Pull apart the two sides of the tablet, exposing the circuit board, battery, and other components of the tablet.
      FixBot'a Sor
      Yorum Ekle
    1. Emerson EM744 Battery  Replacement, Battery: adım 3, 3 resimden 1. Emerson EM744 Battery  Replacement, Battery: adım 3, 3 resimden 2. Emerson EM744 Battery  Replacement, Battery: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      FixBot'a Sor
      Yorum Ekle
    2. Emerson EM744 Battery  Replacement: adım 4, 1 resimden 1.
      • Desolder the positive (red) wire to the positive (+) lead, followed by desoldering the negative (black) wire to the negative lead.
      • Refer to the soldering technique guide.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Akinola
165 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Blackwell Fall 2016 USF Tampa, Team 2-5, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S2G5
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
where can i find the battery replacement for the emerson model em744
tjbblitch - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 30
Her zaman: 1,554
