Giriş
This aim of this guide is to outline in an explicit way the steps to changing the battery of this device, safely and risk free. If your device fails to start this guide will be helpful for you.
Neye ihtiyacın var
Use a Phillips 00 bit to remove two 3mm screws from the bottom of the tablet.
Desolder the positive (red) wire to the positive (+) lead, followed by desoldering the negative (black) wire to the negative lead.
Refer to the soldering technique guide.
