Ana içeriğe geç
Epomaker Shadow-X PCB Replacement
Neye ihtiyacın var
  1. Epomaker Shadow-X PCB Replacement, PCB: adım 1, 1 resimden 1.
    • Power off the keyboard and unplug any attached cables.
    • Place the keyboard on a clean, static-free workspace and wear an anti-static wrist strap if available.
  2. Epomaker Shadow-X PCB Replacement: adım 2, 3 resimden 1. Epomaker Shadow-X PCB Replacement: adım 2, 3 resimden 2. Epomaker Shadow-X PCB Replacement: adım 2, 3 resimden 3.
    • Use a keycap puller to remove all keycaps from the keyboard.
    • Remove all eight of the hex screws that secure the lower case.
    • Remove the lower case.
  3. Epomaker Shadow-X PCB Replacement: adım 3, 1 resimden 1.
    • Locate the PCB, which is mounted below the switch plate.
    • Disconnect any cables or connectors between the PCB and other components
    • Remove any screws or clips securing the PCB to the keyboard case. Carefully lift the PCB out of the case.
    • If there is adhesive or sticky residue holding it, gently work around the edges to release it without damaging components.
  4. Epomaker Shadow-X PCB Replacement: adım 4, 1 resimden 1.
    • Place the new PCB into the same position in the case, aligning all mounting holes and connectors.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Beck Spitler
611 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 222
