Giriş
If the image is blurred, out of focus or distorted, and the cause is not in the menu settings or lens smudges, the projector lens may need to be replaced. Prior to replacement, refer to the Troubleshooting page for additional solutions. Follow this guide to replace the projector lens of your Epson PowerLite 83+ projector.
Before beginning this repair, make sure the the projector is off and unplugged from the power adapter.
Neye ihtiyacın var
Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
Lift the motherboard from the front side of the projector to clear the ribbon cables.
Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
Remove the motherboard from the case.
Remove the four 6 mm Phillips #2 screws securing the fan bracket.
Remove the fan bracket by pulling straight up and set it aside.
