Ana içeriğe geç
Epson PowerLite 83+ Speaker Replacement
Neye ihtiyacın var
  1. Epson PowerLite 83+ Speaker Replacement, Motherboard: adım 1, 3 resimden 1. Epson PowerLite 83+ Speaker Replacement, Motherboard: adım 1, 3 resimden 2. Epson PowerLite 83+ Speaker Replacement, Motherboard: adım 1, 3 resimden 3.
    • Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
    • A long shank Phillips #2 screwdriver is required to reach the screws.
  2. Epson PowerLite 83+ Speaker Replacement: adım 2, 3 resimden 1. Epson PowerLite 83+ Speaker Replacement: adım 2, 3 resimden 2. Epson PowerLite 83+ Speaker Replacement: adım 2, 3 resimden 3.
    • Flip the projector over and lift the top cover from the rear of the projector.
    • Two cables are connected at the front that prevent full removal.
    • Disconnect the slide cover JST connector. Grip the connector and rock it back and forth while apply gentle pressure.
  3. Epson PowerLite 83+ Speaker Replacement: adım 3, 2 resimden 1. Epson PowerLite 83+ Speaker Replacement: adım 3, 2 resimden 2.
    • Using a spudger, lift the ribbon cable's locking tab along the length of the cable.
    • Remove the ribbon cable from the connector and place the projector's top cover aside.
  4. Epson PowerLite 83+ Speaker Replacement: adım 4, 3 resimden 1. Epson PowerLite 83+ Speaker Replacement: adım 4, 3 resimden 2. Epson PowerLite 83+ Speaker Replacement: adım 4, 3 resimden 3.
    • Remove the two 6 mm Phillips #2 screws.
    • Remove the single silver 5 mm Phillips #2 screw.
  5. Epson PowerLite 83+ Speaker Replacement: adım 5, 3 resimden 1. Epson PowerLite 83+ Speaker Replacement: adım 5, 3 resimden 2. Epson PowerLite 83+ Speaker Replacement: adım 5, 3 resimden 3.
    • Using your fingernails or a spudger, remove the eleven JST connectors attached to the motherboard.
  6. Epson PowerLite 83+ Speaker Replacement: adım 6, 2 resimden 1. Epson PowerLite 83+ Speaker Replacement: adım 6, 2 resimden 2.
    • Using a spudger, flip up the plastic locking tabs and gently remove the three ribbon cables from their connectors.
  7. Epson PowerLite 83+ Speaker Replacement: adım 7, 2 resimden 1. Epson PowerLite 83+ Speaker Replacement: adım 7, 2 resimden 2.
    • Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
    • Lift the motherboard from the front side of the projector to clear the ribbon cables.
    • Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
    • Remove the motherboard from the case.
  8. Epson PowerLite 83+ Speaker Replacement, Exhaust Fan: adım 8, 2 resimden 1. Epson PowerLite 83+ Speaker Replacement, Exhaust Fan: adım 8, 2 resimden 2.
    • Loosen the two captive Phillips #2 screws securing the lamp.
    • Captive screws should not be removed. They are secured to the lamp itself with retaining rings and will be removed along with the lamp.
  9. Epson PowerLite 83+ Speaker Replacement: adım 9, 1 resimden 1.
    • Hold onto the indented areas of the lamp with your fingers and gently pull it upwards to remove it from the casing.
  10. Epson PowerLite 83+ Speaker Replacement: adım 10, 3 resimden 1. Epson PowerLite 83+ Speaker Replacement: adım 10, 3 resimden 2. Epson PowerLite 83+ Speaker Replacement: adım 10, 3 resimden 3.
    • Remove the four 6 mm Phillips #2 screws.
    • Lift the fan bracket straight up to remove it from the casing.
  11. Epson PowerLite 83+ Speaker Replacement: adım 11, 2 resimden 1. Epson PowerLite 83+ Speaker Replacement: adım 11, 2 resimden 2.
    • A long, thin shank Phillips #2 screwdriver is required to remove the screws.
  12. Epson PowerLite 83+ Speaker Replacement: adım 12, 2 resimden 1. Epson PowerLite 83+ Speaker Replacement: adım 12, 2 resimden 2.
    • Remove the exhaust fan from the bracket.
  13. Epson PowerLite 83+ Speaker Replacement, Projector Lens: adım 13, 3 resimden 1. Epson PowerLite 83+ Speaker Replacement, Projector Lens: adım 13, 3 resimden 2. Epson PowerLite 83+ Speaker Replacement, Projector Lens: adım 13, 3 resimden 3.
    • Remove the four 6 mm Phillips #2 screws securing the fan bracket.
    • Remove the fan bracket by pulling straight up and set it aside.
  14. Epson PowerLite 83+ Speaker Replacement: adım 14, 3 resimden 1. Epson PowerLite 83+ Speaker Replacement: adım 14, 3 resimden 2. Epson PowerLite 83+ Speaker Replacement: adım 14, 3 resimden 3.
    • Remove the four 6 mm Phillips #2 screws securing the projector lens.
  15. Epson PowerLite 83+ Speaker Replacement: adım 15, 2 resimden 1. Epson PowerLite 83+ Speaker Replacement: adım 15, 2 resimden 2.
    • Unhook the JST connector wire from wire stay and move it aside.
    • Remove the projector lens from the base.
  16. Epson PowerLite 83+ Speaker Replacement, Speaker: adım 16, 2 resimden 1. Epson PowerLite 83+ Speaker Replacement, Speaker: adım 16, 2 resimden 2.
    • Remove the three 6 mm Phillips #2 screws.
  17. Epson PowerLite 83+ Speaker Replacement: adım 17, 1 resimden 1.
    • Remove the speaker from the projector case.
Sonuç
Lucas Bell
229 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-4, Hunter Spring 2022 Clemson, Team 2-4, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S2G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 83
