Ana içeriğe geç
Epson Powerlite 460 Fan Replacement
Neye ihtiyacın var
  1. Epson Powerlite 460 Fan Replacement, Motherboard: adım 1, 2 resimden 1. Epson Powerlite 460 Fan Replacement, Motherboard: adım 1, 2 resimden 2.
    • Orient the device so that the projection window is facing down and the bottom of the device is visible.
    • Remove the eleven 13.3mm screws using a Phillips #2 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Epson Powerlite 460 Fan Replacement: adım 2, 3 resimden 1. Epson Powerlite 460 Fan Replacement: adım 2, 3 resimden 2. Epson Powerlite 460 Fan Replacement: adım 2, 3 resimden 3.
    • Flip the device over so that the projection window is facing up.
    • Slide the air filter cover opener in the direction indicated by the arrow to release the air filter cover.
    • Remove the air filter cover.
    FixBot'a Sor
    Yorum Ekle
  3. Epson Powerlite 460 Fan Replacement: adım 3, 2 resimden 1. Epson Powerlite 460 Fan Replacement: adım 3, 2 resimden 2.
    • Remove the two 13.3mm screws from the top cover above the air filter using a Phillips #2 screwdriver.
    • Remove one 13.3mm screw from above the connection panel using a Phillips #2 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Epson Powerlite 460 Fan Replacement: adım 4, 2 resimden 1. Epson Powerlite 460 Fan Replacement: adım 4, 2 resimden 2.
    • Remove the cover from the projector and set aside.
    • The cover will be connected by ribbon cables. You do not need to disconnect these to complete this repair, but it may make it easier.
    FixBot'a Sor
    Yorum Ekle
  5. Epson Powerlite 460 Fan Replacement: adım 5, 3 resimden 1. Epson Powerlite 460 Fan Replacement: adım 5, 3 resimden 2. Epson Powerlite 460 Fan Replacement: adım 5, 3 resimden 3.
    • Use the opening tool to disconnect eleven clip cables on the motherboard.
    • These will be the colorful cables connected with white plastic clips.
    • Disconnect the black cable clip by pressing the side tabs. Use the opening tool to release the cable if it is difficult.
    • To disconnect the ribbon cables, use the opening tool to lift the locking flap on the connector and slide the cable back and out of the connector.
    FixBot'a Sor
    Yorum Ekle
  6. Epson Powerlite 460 Fan Replacement: adım 6, 1 resimden 1.
    • Disconnect the clip cable from below the motherboard and behind the connection panel.
    FixBot'a Sor
    Yorum Ekle
  7. Epson Powerlite 460 Fan Replacement: adım 7, 3 resimden 1. Epson Powerlite 460 Fan Replacement: adım 7, 3 resimden 2. Epson Powerlite 460 Fan Replacement: adım 7, 3 resimden 3.
    • Remove seven 8.1mm screws from the motherboard using a Phillips #2 screwdriver.
    • Remove the 8.1mm screw from the back of the projection panel below the motherboard using a Phillips #2 screwdriver.
    • Remove two 8.1mm screws from the front of the projection panel using a Phillips #2 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Epson Powerlite 460 Fan Replacement: adım 8, 1 resimden 1.
    • Gently lift the motherboard out of the device.
    FixBot'a Sor
    Yorum Ekle
  9. Epson Powerlite 460 Fan Replacement, Lens: adım 9, 2 resimden 1. Epson Powerlite 460 Fan Replacement, Lens: adım 9, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the two 9.1mm screws from the focus lever adjuster.
    • Remove the focus lever mechanism by sliding the metal rod out of the plastic lever and lifting out of the unit.
    FixBot'a Sor
    Yorum Ekle
  10. Epson Powerlite 460 Fan Replacement: adım 10, 2 resimden 1. Epson Powerlite 460 Fan Replacement: adım 10, 2 resimden 2.
    • Remove the two 13.3mm screws from the metal bracket surrounding the lens unit using a Phillips #0 screwdriver.
    • Remove the bracket.
    FixBot'a Sor
    Yorum Ekle
  11. Epson Powerlite 460 Fan Replacement: adım 11, 2 resimden 1. Epson Powerlite 460 Fan Replacement: adım 11, 2 resimden 2.
    • Remove the two 13.3mm screws from the lens cover using a Phillips #0 screwdriver.
    • Use your finger to release the clips on either side of the lens cover.
    • Lift the lens cover to remove it from the projector.
    FixBot'a Sor
    Yorum Ekle
  12. Epson Powerlite 460 Fan Replacement: adım 12, 2 resimden 1. Epson Powerlite 460 Fan Replacement: adım 12, 2 resimden 2.
    • Remove the five 9.4mm screws from the lens using a Phillips #0 screwdriver.
    • Lift the lens out of the unit.
    FixBot'a Sor
    Yorum Ekle
  13. Epson Powerlite 460 Fan Replacement, Fan: adım 13, 2 resimden 1. Epson Powerlite 460 Fan Replacement, Fan: adım 13, 2 resimden 2.
    • Remove the two 13.3 mm screws on the parabolic dish/mirror.
    • Pull out the parabolic dish/mirror.
    FixBot'a Sor
    Yorum Ekle
  14. Epson Powerlite 460 Fan Replacement: adım 14, 1 resimden 1.
    • Remove the four 13.4 mm screws from the fan cover.
    FixBot'a Sor
    Yorum Ekle
  15. Epson Powerlite 460 Fan Replacement: adım 15, 2 resimden 1. Epson Powerlite 460 Fan Replacement: adım 15, 2 resimden 2.
    • Remove the two 13.3 mm screws from the side of the air filter cover.
    FixBot'a Sor
    Yorum Ekle
  16. Epson Powerlite 460 Fan Replacement: adım 16, 2 resimden 1. Epson Powerlite 460 Fan Replacement: adım 16, 2 resimden 2.
    • Remove the two 13.4 mm screws from the fan.
    • Remove the fan.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Sydney Roybal
109 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 665
