Giriş
Use this guide to replace a dirty or damaged lens inside the Epson Powerlite 460 projector.
A lens works by passing light from the projection source through a series of mirrors and then projecting it upwards onto a transparent plate at the top of the machine. The image is then projected onto a screen for display.
A dirty or damaged lens can cause your projection to be blurry or unclear. Use this guide to remove the lens from the projector so you can clean or replace it.
Review the troubleshooting guide; sometimes, a distorted image is the cause of another issue and does not require the lens to be replaced.
Neye ihtiyacın var
Orient the device so that the projection window is facing down and the bottom of the device is visible.
Remove the eleven 13.3mm screws using a Phillips #2 screwdriver.
Use the opening tool to disconnect eleven clip cables on the motherboard.
Disconnect the black cable clip by pressing the side tabs. Use the opening tool to release the cable if it is difficult.
To disconnect the ribbon cables, use the opening tool to lift the locking flap on the connector and slide the cable back and out of the connector.
Remove seven 8.1mm screws from the motherboard using a Phillips #2 screwdriver.
Remove the 8.1mm screw from the back of the projection panel below the motherboard using a Phillips #2 screwdriver.
Remove two 8.1mm screws from the front of the projection panel using a Phillips #2 screwdriver.
Use a Phillips #0 screwdriver to remove the two 9.1mm screws from the focus lever adjuster.
Remove the focus lever mechanism by sliding the metal rod out of the plastic lever and lifting out of the unit.
