Ana içeriğe geç
Epson VS250 Fan Replacement
Neye ihtiyacın var
  1. Epson VS250 Fan Replacement, Shell: adım 1, 1 resimden 1.
    • Place the projector on a flat surface.
    • Orient the projector so that the the word "Epson" is facing you.
    • Using the Phillips #1 screwdriver, to loosen the screw on the top right corner of the projector. The screw only needs to be loosened.
    FixBot'a Sor
    Yorum Ekle
  2. Epson VS250 Fan Replacement: adım 2, 1 resimden 1.
    • Slide the cover to the right and lift the cover up and out to remove.
    FixBot'a Sor
    Yorum Ekle
  3. Epson VS250 Fan Replacement: adım 3, 1 resimden 1.
    • Using a Phillips #1 screwdriver, remove the three 6 mm screws that hold the side portion of the projector in place.
    • Use the same Phillips #1 screwdriver to remove the single 10 mm screw that is holding the side cover of the projector in place.
    FixBot'a Sor
    Yorum Ekle
  4. Epson VS250 Fan Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws that are holding the side cover of the projector in place.
    FixBot'a Sor
    Yorum Ekle
  5. Epson VS250 Fan Replacement: adım 5, 2 resimden 1. Epson VS250 Fan Replacement: adım 5, 2 resimden 2.
    • Flip the projector so that it lays upside down.
    • Using a Phillips #1 screwdriver, remove the eight 10 mm screws that secure the side portion of the projector.
    FixBot'a Sor
    Yorum Ekle
  6. Epson VS250 Fan Replacement: adım 6, 1 resimden 1.
    • Remove the front cover from the projector by pulling it off of the device.
    FixBot'a Sor
    Yorum Ekle
  7. Epson VS250 Fan Replacement: adım 7, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws.
    • After completing this step you will be able to remove the back cover from the projector.
    FixBot'a Sor
    Yorum Ekle
  8. Epson VS250 Fan Replacement: adım 8, 1 resimden 1.
    • Slowly lift up the top shell up and out of the device.
    • Disconnect the ribbon cable from the motherboard and remove the shell from the device.
    FixBot'a Sor
    Yorum Ekle
  9. Epson VS250 Fan Replacement, Fan: adım 9, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the five 10 mm screws.
    FixBot'a Sor
    Yorum Ekle
  10. Epson VS250 Fan Replacement: adım 10, 3 resimden 1. Epson VS250 Fan Replacement: adım 10, 3 resimden 2. Epson VS250 Fan Replacement: adım 10, 3 resimden 3.
    • Unplug the fan connector from the circuit board.
    • Remove the wires from the hooks that secure them to free the fan.
    FixBot'a Sor
    Yorum Ekle
  11. Epson VS250 Fan Replacement: adım 11, 2 resimden 1. Epson VS250 Fan Replacement: adım 11, 2 resimden 2.
    • Disconnect the wire and remove the black casing from the rest of the fan assembly.
    FixBot'a Sor
    Yorum Ekle
  12. Epson VS250 Fan Replacement: adım 12, 2 resimden 1. Epson VS250 Fan Replacement: adım 12, 2 resimden 2.
    • Remove the fan from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
Warren Cutlip
604 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 4-2, Hunter Fall 2021 Clemson, Team 4-2, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S4G2
5 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 727
