Ana içeriğe geç
Equity Alarm Clock 13014 Alarm Switch Replacement
Neye ihtiyacın var
  1. Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: adım 1, 3 resimden 1. Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: adım 1, 3 resimden 2. Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: adım 1, 3 resimden 3.
    • Remove the battery door using your finger nail or an opening tool.
  2. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: adım 2, 2 resimden 1. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the 3 screws on the back cover.
  3. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove Cover: adım 3, 1 resimden 1.
    • Remove the back cover gently.
    • DO NOT pull the back cover off quickly or you may damage the wires connected.
  4. Equity Alarm Clock 13014 Alarm Switch Replacement: adım 4, 2 resimden 1. Equity Alarm Clock 13014 Alarm Switch Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the small screw located above the alarm switch.
    • Remove the small screw located below the alarm switch as well.
  5. Equity Alarm Clock 13014 Alarm Switch Replacement: adım 5, 2 resimden 1. Equity Alarm Clock 13014 Alarm Switch Replacement: adım 5, 2 resimden 2.
    • Place the end of the soldering iron on the end of the wire connected to the copper cylinder to detach the wire.
    • If you are unfamiliar with soldering, take a look at this article: How to Solder and Desolder Connections.
    • To replace the alarm switch, attach one end of new alarm switch wire to the copper cylinder.
    • Use a Phillips #1 screwdriver to reinstall the switch screws.
    • Follow steps in reverse order to assemble the clock.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alaa
311 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 1,085
