Giriş
If the alarm on your Equity Alarm Clock 13014 is not going off, use this guide to replace the alarm switch.
The alarm switch is a small lever that is flipped, at the set time of the alarm, to activate an internal circuit which in response triggers the alarm to sound. A faulty alarm switch will not activate the internal circuit therefore, never triggering the sound.
Step 5 requires knowledge of basic soldering to detach a wire.
Here is a helpful video on basic soldering: Lehimleme ve Lehim Sökme Bağlantıları Nasıl Yapılır
Neye ihtiyacın var
Remove the battery door using your finger nail or an opening tool.
Use a Phillips #1 screwdriver to remove the 3 screws on the back cover.
3 farklı kişi bu kılavuzu tamamladı.
