Ana içeriğe geç
Eureka EasyClean 71C Power Cord Replacement
Neye ihtiyacın var
  1. Eureka EasyClean 71C Power Cord Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
  2. Eureka EasyClean 71C Power Cord Replacement: adım 2, 1 resimden 1.
    • Pry off the Riser Visor using the plastic opening tool.
  3. Eureka EasyClean 71C Power Cord Replacement: adım 3, 1 resimden 1.
    • Remove the screw cap using the metal spudger.
    • First-time removal of the screw cap can be difficult. The screw cap isn’t vital, so don’t worry about damaging the screw cap and just keep trying until it comes out.
  4. Eureka EasyClean 71C Power Cord Replacement: adım 4, 2 resimden 1. Eureka EasyClean 71C Power Cord Replacement: adım 4, 2 resimden 2.
    • Unscrew the 14mm PH2 Phillips head screw.
    • Pull the bottom cover off of the rest of the casing.
  5. Eureka EasyClean 71C Power Cord Replacement, Casing: adım 5, 1 resimden 1.
    • Pull the power switch all the way up and remove the dust cup.
  6. Eureka EasyClean 71C Power Cord Replacement: adım 6, 2 resimden 1. Eureka EasyClean 71C Power Cord Replacement: adım 6, 2 resimden 2.
    • Unscrew the six 18.1mm PH2 Phillips head screws on the side of the vacuum.
    • Pull the casing apart.
  7. Eureka EasyClean 71C Power Cord Replacement, Power Cord: adım 7, 1 resimden 1.
    • Pull out the switch board.
    • Ensure the vacuum is powered off and unplugged before handling any electronics.
  8. Eureka EasyClean 71C Power Cord Replacement: adım 8, 2 resimden 1. Eureka EasyClean 71C Power Cord Replacement: adım 8, 2 resimden 2.
    • Desolder the highlighted black and white wires.
    • For instructions on how to solder and desolder wires, visit this guide.
  9. Eureka EasyClean 71C Power Cord Replacement: adım 9, 1 resimden 1.
    • Unscrew the 22.3mm PH2 Phillips head screw.
    • Remove the power cord.
Sonuç
Tanner Durnil
631 İtibar
6 adet Kılavuz yazıldı
Ekip
IUPUI, Team S6-G4, Baechle Fall 2017 IUPUI, Team S6-G4, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S6G4
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 360
