Giriş
This guide will help you replace a dial for a Fahrenheit FHT 125PRMR hair straightener that is not properly controlling the temperature of the device when powered on. Make sure the device is unplugged when working on it to avoid damaging any electrical components.
Neye ihtiyacın var
Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
Using a soldering tool, remove the dial station by carefully desoldering the metal on the connecting pins to the motherboard.
