Ana içeriğe geç
Fahrenheit FHT 125PRMR Dial Replacement
Neye ihtiyacın var
  1. Fahrenheit FHT 125PRMR Dial Replacement, Dial: adım 1, 1 resimden 1.
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Dial Replacement: adım 2, 1 resimden 1.
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Dial Replacement: adım 3, 2 resimden 1. Fahrenheit FHT 125PRMR Dial Replacement: adım 3, 2 resimden 2.
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Dial Replacement: adım 4, 2 resimden 1. Fahrenheit FHT 125PRMR Dial Replacement: adım 4, 2 resimden 2.
    • Using a Philips head #1 screwdriver remove the two 6mm black screws on both sides of the dial panel cover.
  5. Fahrenheit FHT 125PRMR Dial Replacement: adım 5, 1 resimden 1.
    • Using a Philips head #1 screwdriver remove the two 4mm silver screws on both sides of the dial panel cover.
  6. Fahrenheit FHT 125PRMR Dial Replacement: adım 6, 2 resimden 1. Fahrenheit FHT 125PRMR Dial Replacement: adım 6, 2 resimden 2.
    • Using a Philips head #00 screwdriver remove the 4mm silver screw from the center of the dial.
    • Remove the dial after the screw is removed with either your hand or a plastic opening tool.
  7. Fahrenheit FHT 125PRMR Dial Replacement: adım 7, 1 resimden 1.
    • Remove the covering panel by pulling up with your hand.
  8. Fahrenheit FHT 125PRMR Dial Replacement: adım 8, 1 resimden 1.
Sonuç
Nicolas Moreau
180 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-2, Harley Fall 2016 IUPUI, Team 2-2, Harley Fall 2016 üyesi
IUPUI-HARLEY-F16S2G2
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 824
