Ana içeriğe geç
Fahrenheit FHT 125PRMR Heating Plate Replacement
Neye ihtiyacın var
  1. Fahrenheit FHT 125PRMR Heating Plate Replacement, Heating Plate: adım 1, 1 resimden 1.
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Heating Plate Replacement: adım 2, 1 resimden 1.
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Heating Plate Replacement: adım 3, 2 resimden 1. Fahrenheit FHT 125PRMR Heating Plate Replacement: adım 3, 2 resimden 2.
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Heating Plate Replacement: adım 4, 1 resimden 1.
    • Using Philips head (PH1) remove the 6 mm black screw that was underneath the spring as well as the 6 mm black screw next to the heating plate. Remove the panel the screws were holding down.
  5. Fahrenheit FHT 125PRMR Heating Plate Replacement: adım 5, 1 resimden 1.
    • Using Philips head (PH1) remove the two 4 mm silver screws on the sides of dial panel cover
  6. Fahrenheit FHT 125PRMR Heating Plate Replacement: adım 6, 2 resimden 1. Fahrenheit FHT 125PRMR Heating Plate Replacement: adım 6, 2 resimden 2.
    • Using Philips head (PH00) to remove the 4 mm silver screw on the dial. Remove the dial with your hand.
  7. Fahrenheit FHT 125PRMR Heating Plate Replacement: adım 7, 1 resimden 1.
    • Remove the covering panel by pulling up with your hand.
  8. Fahrenheit FHT 125PRMR Heating Plate Replacement: adım 8, 1 resimden 1.
  9. Fahrenheit FHT 125PRMR Heating Plate Replacement: adım 9, 2 resimden 1. Fahrenheit FHT 125PRMR Heating Plate Replacement: adım 9, 2 resimden 2.
    • Remove 3 sliver screws (3mm) (PH1) from the motherboard.
  10. Fahrenheit FHT 125PRMR Heating Plate Replacement: adım 10, 1 resimden 1.
Sonuç
Omar El Mounayri
61 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-2, Harley Fall 2016 IUPUI, Team 2-2, Harley Fall 2016 üyesi
IUPUI-HARLEY-F16S2G2
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 2,158
