Ana içeriğe geç
Fahrenheit FHT 125PRMR Motherboard Replacement
Neye ihtiyacın var
    1. Fahrenheit FHT 125PRMR Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
      • Remove both hinge covers on each side of the flat iron.
      FixBot'a Sor
      Yorum Ekle
    2. Fahrenheit FHT 125PRMR Motherboard Replacement: adım 2, 1 resimden 1.
      • Using Philips head #2 remove the 7 mm black screw that was underneath one of the hinge covers.
      FixBot'a Sor
      Yorum Ekle
    3. Fahrenheit FHT 125PRMR Motherboard Replacement: adım 3, 2 resimden 1. Fahrenheit FHT 125PRMR Motherboard Replacement: adım 3, 2 resimden 2.
      • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
      • When the pin is removed the two sides of the device can now separate.
      • Be sure to collect the spring that is next to the hinge when they are separated.
      FixBot'a Sor
      Yorum Ekle
    4. Fahrenheit FHT 125PRMR Motherboard Replacement: adım 4, 2 resimden 1. Fahrenheit FHT 125PRMR Motherboard Replacement: adım 4, 2 resimden 2.
      • Using Philips head #1 remove the 6 mm black screw that was underneath the spring as well as the 6 mm black screw next to the heating plate. Remove the panel the screws were holding down.
      FixBot'a Sor
      Yorum Ekle
    5. Fahrenheit FHT 125PRMR Motherboard Replacement: adım 5, 1 resimden 1.
      • Using Philips head #1 remove the two 4 mm silver screws on the sides of dial panel cover.
      FixBot'a Sor
      Yorum Ekle
    6. Fahrenheit FHT 125PRMR Motherboard Replacement: adım 6, 2 resimden 1. Fahrenheit FHT 125PRMR Motherboard Replacement: adım 6, 2 resimden 2.
      • Using Philips head #00 to remove the 4 mm silver screw on the dial. Remove the dial with your hand.
      FixBot'a Sor
      Yorum Ekle
    7. Fahrenheit FHT 125PRMR Motherboard Replacement: adım 7, 1 resimden 1.
      • Remove the covering panel by pulling up with your hand.
      FixBot'a Sor
      Yorum Ekle
    8. Fahrenheit FHT 125PRMR Motherboard Replacement: adım 8, 2 resimden 1. Fahrenheit FHT 125PRMR Motherboard Replacement: adım 8, 2 resimden 2.
      • Remove three 3 mm sliver screws #1 from the motherboard.
      • Use your hand to life the motherboard out of the flat iron.
      FixBot'a Sor
      Yorum Ekle
    9. Fahrenheit FHT 125PRMR Motherboard Replacement: adım 9, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
Sonuç
MeKenzie Hilsmeyer
23 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-2, Harley Fall 2016 IUPUI, Team 2-2, Harley Fall 2016 üyesi
IUPUI-HARLEY-F16S2G2
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 1,965
