Ana içeriğe geç
Fairphone 3 Display Module Replacement
Neye ihtiyacın var
  1. Fairphone 3 Display Module Replacement, Back Cover: adım 1, 2 resimden 1. Fairphone 3 Display Module Replacement, Back Cover: adım 1, 2 resimden 2.
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
    FixBot'a Sor
    Yorum Ekle
  2. Fairphone 3 Display Module Replacement: adım 2, 3 resimden 1. Fairphone 3 Display Module Replacement: adım 2, 3 resimden 2. Fairphone 3 Display Module Replacement: adım 2, 3 resimden 3.
    • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Fairphone 3 Display Module Replacement, Battery: adım 3, 2 resimden 1. Fairphone 3 Display Module Replacement, Battery: adım 3, 2 resimden 2.
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lever the battery up until you can get a good grip.
    FixBot'a Sor
    Yorum Ekle
  4. Fairphone 3 Display Module Replacement: adım 4, 2 resimden 1. Fairphone 3 Display Module Replacement: adım 4, 2 resimden 2.
    • Lift the battery out of its recess and remove it.
    FixBot'a Sor
    Yorum Ekle
  5. Fairphone 3 Display Module Replacement, Display Assembly: adım 5, 1 resimden 1.
    • Whenever a Phillips #00 screw is mentioned you can also unfasten it with a size #0 bit/screwdriver.
    • Remove the thirteen Phillips #00 screws (4 mm length).
    FixBot'a Sor
    Yorum Ekle
  6. Fairphone 3 Display Module Replacement: adım 6, 3 resimden 1. Fairphone 3 Display Module Replacement: adım 6, 3 resimden 2. Fairphone 3 Display Module Replacement: adım 6, 3 resimden 3.
    • Make sure to insert the opening pick between the midframe and the display module and not into the small gap next to the screen. Otherwise you're going to pry up the screen instead of the whole display module.
    • Insert an opening pick between the midframe and the display module on the right edge of the phone.
    • Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
    FixBot'a Sor
    Yorum Ekle
  7. Fairphone 3 Display Module Replacement: adım 7, 2 resimden 1. Fairphone 3 Display Module Replacement: adım 7, 2 resimden 2.
    • Slide the opening pick around the bottom right corner and use it to disengage the plastic clamps at the bottom of the display module.
    FixBot'a Sor
    Yorum Ekle
  8. Fairphone 3 Display Module Replacement: adım 8, 2 resimden 1. Fairphone 3 Display Module Replacement: adım 8, 2 resimden 2.
    • Slide the opening pick along the left side to pry the display module up.
    • The display module should pop out of the midframe during this process. In case it doesn’t, check for remaining clamps you might have missed.
    FixBot'a Sor
    Yorum Ekle
  9. Fairphone 3 Display Module Replacement: adım 9, 2 resimden 1. Fairphone 3 Display Module Replacement: adım 9, 2 resimden 2.
    • Remove the display assembly.
    • To reinstall the display-module press it into place on all sides until you can hear a snap from the plastic clamps to make sure it sits flush with the frame.
    • If you install a new display: The new display module comes with a white plastic cover held by 2 screws over the processor and the connectors. This needs to be taken off.
    FixBot'a Sor
    Yorum Ekle
Sonuç
51 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
259.285 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
25.946 adet Kılavuz yazıldı
24Kılavuz Yorumları
Pick goes in much easier on the left side. Then round the bottom and work it onto the right side.
Bert Ober - Yanıt Paylaş
bonjour,
Excellent tutoriel, merci!
Mon Fairphone ne se sent plus de joie!
Martine
Martine R - Yanıt Paylaş
Bonjour,
Mon écran est noir depuis une chute, mais il n’y a aucun impact.
Je voudrais bien le changer, mais comment être sure que le problème ne vient que de l’écran? A 90e la pièce, ça m’embêterait de me tromper de problème… Merci de votre aide
hélène Petit - Yanıt Paylaş
Bonjour,
Je suppose que depuis ce temps là vous avez trouvé une solution…
Mais, à toute fin utile dans cette page, le démontage (nettoyage des contacts) remontage a permis de refaire fonctionner l’écran d’un FAIRPHONE3 qui ne répondait plus au toucher !
La déconnexion-reconnexion de la carte mère y est aussi peut-être pour quelque chose…
Marette - Yanıt Paylaş
Merci pour votre commentaire. J'ai eu exactement le même problème. EN tombant sur ce site, j'ai lu vos commentaires, et la réponse qu'on vous a apporté. J'ai donc démonter le module écran comme indiqué dans ce tuto (très bien fait, la partie avec le médiator m'a laissé perplexe, en faite il suffit aussi de tirer légèrement depuis le boitier de la batterie pour déclipser le module écran), et de remonter le module écran. Et la lumière fairphone réapparut, alors que je pensais devoir changer mon module écran.
Merci infiniment
Margot Aigon - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 93
Son 30 gün: 360
Her zaman: 45,377
