Giriş
Use this guide to replace a broken or defective screen on your Fairphone 4.
Neye ihtiyacın var
Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
Pry the back cover up to start separating its plastic clips.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Lift the battery out of its recess and remove it.
Remove the battery.
Flip the phone over so the screen faces up
Insert an opening pick between the screen and the frame.
Grab the screen and lift it straight up just enough to clear its pegs from the frame.
Rotate the display carefully clock-wise and flip it over to get access to the connector.
Place the display on the device with the screen facing downwards.
Use an opening pick to pry up and disconnect the display connection cable.
Remove the screen.
29 farklı kişi bu kılavuzu tamamladı.
16Kılavuz Yorumları
20-40 Minutes? ... more like 10 ... and I wasn't even pushing it
Thanks for your comment! The time estimate was set a little too high, you're right. I've adjusted it!
10 minutes, like you. Honnestly I'm so happy to be apple to fix it by my own. Thanks to the Fairphone's engineers. I would never buy another phone yet. And I hope I could keep this one 10 more years!
