Ana içeriğe geç
Felt Z85 Brake Pad Replacement
Ryan Marschall
Ryan Marschall ve başka bir katkıda bulunan
En son January 11, 2015 tarihinde güncellendi
10 dakika
Kolay
Hatalı İşaretlenmiş
The brakes on anything that moves are practically the most important part. One of the most frightening feelings is pulling a brake lever and not getting a response. With this guide I hope to never make this a reality for anyone.
This guide contains information on how to replace the brake pads on a 2013 Felt Z85 Road Bike. This guide only requires one tool (4mm allen key) and is fairly straightforward.
This guide can also be used as a reference for any modern road bike with Dual-Pivot brakes.
  1. Felt Z85 Brake Pad Replacement, Remove Wheel: adım 1, 3 resimden 1. Felt Z85 Brake Pad Replacement, Remove Wheel: adım 1, 3 resimden 2. Felt Z85 Brake Pad Replacement, Remove Wheel: adım 1, 3 resimden 3.
    • Pull up on brake-release lever to spread pads for easy access.
    • Release lever on the right side of the wheel.
    • Loosen left nut on wheel until wheel comes free.
  2. Felt Z85 Brake Pad Replacement, Remove Pad(s): adım 2, 3 resimden 1. Felt Z85 Brake Pad Replacement, Remove Pad(s): adım 2, 3 resimden 2. Felt Z85 Brake Pad Replacement, Remove Pad(s): adım 2, 3 resimden 3.
    • Locate Brake Caliper.
    • Use 4.0 mm allen key to remove main bolt.
    • Rotate counterclockwise to loosen.
    • Be careful not to lose both the washer and spacer found in-between the bolt and the brake pad mounting hole.
    • Repeat step 2 to remove the pad on the other side.
  3. Felt Z85 Brake Pad Replacement, Collecting parts (reinstall): adım 3, 2 resimden 1. Felt Z85 Brake Pad Replacement, Collecting parts (reinstall): adım 3, 2 resimden 2.
    • Brake Pad: The item being replaced.
    • Spacer: This item will be reused.
    • Washer: This item will be reused.
    • 4 mm hex bolt.
    • Note order of mounting hardware for reinstall.
Sonuç
Ryan Marschall
123 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-21, Donnelly Fall 2014 USF Tampa, Team 1-21, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G21
1 Üye
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,060
