Ana içeriğe geç
Fitbit Blaze Vibration Motor Replacement
Neye ihtiyacın var
  1. Fitbit Blaze  Vibration Motor Replacement, Wristband: adım 1, 2 resimden 1. Fitbit Blaze  Vibration Motor Replacement, Wristband: adım 1, 2 resimden 2.
    • Locate the front LCD screen on your device.
    • Fitbit logo should appear in the bottom center of the screen.
  2. Fitbit Blaze  Vibration Motor Replacement: adım 2, 1 resimden 1.
    • Push the screen out through the back of the metal ring enclosure.
    • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
  3. Fitbit Blaze  Vibration Motor Replacement: adım 3, 3 resimden 1. Fitbit Blaze  Vibration Motor Replacement: adım 3, 3 resimden 2. Fitbit Blaze  Vibration Motor Replacement: adım 3, 3 resimden 3.
    • Locate the metal pin behind the wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
    • Use a small amount of force to avoid damaging the pins.
    • Remove wristband.
    This step is not needed to change the battery . Not sure why it was included.
    Jason Y - Yanıt
  4. Fitbit Blaze  Vibration Motor Replacement, Display Frame: adım 4, 3 resimden 1. Fitbit Blaze  Vibration Motor Replacement, Display Frame: adım 4, 3 resimden 2. Fitbit Blaze  Vibration Motor Replacement, Display Frame: adım 4, 3 resimden 3.
    • Locate the pin behind the second wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into opposite direction.
    • Remove wristband.
  5. Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: adım 5, 3 resimden 1. Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: adım 5, 3 resimden 2. Fitbit Blaze  Vibration Motor Replacement, Vibration Motor: adım 5, 3 resimden 3.
    • Place device screen face down and locate the four screws attaching the back cover.
    • Use a T3 torx head or T3 torx screwdriver to remove the four screws.
  6. Fitbit Blaze  Vibration Motor Replacement: adım 6, 3 resimden 1. Fitbit Blaze  Vibration Motor Replacement: adım 6, 3 resimden 2. Fitbit Blaze  Vibration Motor Replacement: adım 6, 3 resimden 3.
    • Grab the back, lift and open like a book to expose the motherboard. Locate the ribbon connector on the left.
    • Use a plastic spudger tool on the ribbon connected from the heart rate monitor to the motherboard.
    • Insert and lift the plastic opening tool to release the ribbon.
    • Only a small force when lifting the plastic connector is needed to avoid damage.
  7. Fitbit Blaze  Vibration Motor Replacement: adım 7, 3 resimden 1. Fitbit Blaze  Vibration Motor Replacement: adım 7, 3 resimden 2. Fitbit Blaze  Vibration Motor Replacement: adım 7, 3 resimden 3.
    • Separate the back and set aside, locate the three screws attaching the motherboard.
    • Use a PH000 head or a PH000 screwdriver to remove the three screws.
  8. Fitbit Blaze  Vibration Motor Replacement: adım 8, 3 resimden 1. Fitbit Blaze  Vibration Motor Replacement: adım 8, 3 resimden 2. Fitbit Blaze  Vibration Motor Replacement: adım 8, 3 resimden 3.
    • Use a plastic spudger tool on the ribbons connected to the motherboard.
    • Insert the tool under the ribbon and lift to release the connection.
  9. Fitbit Blaze  Vibration Motor Replacement: adım 9, 3 resimden 1. Fitbit Blaze  Vibration Motor Replacement: adım 9, 3 resimden 2. Fitbit Blaze  Vibration Motor Replacement: adım 9, 3 resimden 3.
    • Lift and push the motherboard to the side to uncover the 167mAh battery.
    • Use a plastic spudger tool to pry out the battery from its adhesive plastic underneath.
    • Lift up and pull downward to remove battery. Switch to the top portion of the battery and push downward to pry out battery.
  10. Fitbit Blaze  Vibration Motor Replacement: adım 10, 2 resimden 1. Fitbit Blaze  Vibration Motor Replacement: adım 10, 2 resimden 2.
    • Flip the motherboard back to the front to locate the metal pins from the vibration motor soldered to the board.
    • Desolder the connection to remove the motor component.
    • Follow this guide on how to solder and desolder connectors Soldering Guide
    • Excessive heat will damage the components, so do not apply the soldering iron to the component for long amounts of time.
Sonuç
Adrian Borrego
2.242 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G3, Sullivan Spring 2017 USF Tampa, Team S3-G3, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S3G3
4 Üyeler
15 adet Kılavuz yazıldı
4Kılavuz Yorumları
anyone got a part number or a description of the motor that gets replaced. looking to do this and fix. thanks
Ben - Yanıt
And how many destroyed “FitBit Blaze” are we going to see now?
tjhbob - Yanıt
what kind of motor can you replace this with?
dbick - Yanıt
Any idea what is the value of the C3 capacitor?
P J - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 27
Her zaman: 3,183
