Ana içeriğe geç
Fitbit FB502SBUL Wristband Replacement
Adrian Borrego
Adrian Borrego ve 2 diğer katkıda bulunanlar
En son July 5, 2020 tarihinde güncellendi
15 dakika
Kolay
This guide will show you how to remove and replace your worn out or damaged wristbands.
Neye ihtiyacın var
Aletler
  1. Fitbit FB502SBUL Wristband Replacement, Wristband: adım 1, 2 resimden 1. Fitbit FB502SBUL Wristband Replacement, Wristband: adım 1, 2 resimden 2.
    • Locate the front LCD screen on your device.
    • Fitbit logo should appear in the bottom center of the screen.
  2. Fitbit FB502SBUL Wristband Replacement: adım 2, 1 resimden 1.
    • Push the screen out through the back of the metal ring enclosure.
    • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
  3. Fitbit FB502SBUL Wristband Replacement: adım 3, 3 resimden 1. Fitbit FB502SBUL Wristband Replacement: adım 3, 3 resimden 2. Fitbit FB502SBUL Wristband Replacement: adım 3, 3 resimden 3.
    • Locate the metal pin behind the wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
    • Use a small amount of force to avoid damaging the pins.
    • Remove wristband.
Sonuç
Adrian Borrego
2.242 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G3, Sullivan Spring 2017 USF Tampa, Team S3-G3, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S3G3
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 1,602
