Neye ihtiyacın var
Press Windows + R, type "devmgmt.msc" into the Run dialog, and press OK. Expand Disk drives. Right–click the external hard drive and choose Update Driver Software…
If there are any updates, follow further instructions and your hard disk driver will be updated.
Experienced users will check whether their external hard drive shows up in Disk Management when they find Windows doesn't detect it. To open the Disk Management tool, you can right-click This PC (or My Computer in Windows 7) and choose Manage in the context menu to enter Computer Management, and then select Disk Management on the left.
Once the drive letter is missing, Windows cannot recognize this drive but we can see it in Computer Management window. Now, we have to assign a drive letter to the HDD to make Windows recognize it.
Right-click the external hard drive, and choose Change Drive Letter and Paths…
Click Add, and then pick a letter for the drive and click OK.
Bonjour, merci beaucoup pour ces conseils, j’en avais acheté un, je l’ai reporté car Windows ne le détectait pas, j’en ai eu un autre qu’il ne détectait pas non plus avant de tomber sur vos explications qui m’ont permis de le paramétrer.
When you assign a new drive letter, select a unique one,. If you already have a drive E. Choose a letter with no duplicates allowed,. Which leads to another possibility. Drive letter. Duplication, but you now know how to fix it! Its generally best not to change drive. Letters of your fixed disks which can break links to files and programs... not desirable.
If your drive shows up here, check to see also whether it is online or offline. If it shows offline right click there (on the left) and select online. This may fix it. You might run into this problem when there has been a drive letter conflict, since you can't have duplicated letters, one has to go,. Remember to assign a unique drive letter if there is none.
It did fix my problem, but the question is why it's doing it? It happens on Windows 7.
If you see the external hard drive which is not recognized by Windows is full of "unallocated space," you'll want to create a new partition on it. This will allow Windows and other operating systems to recognize and use this HDD.
As we know, different tools like Windows Disk Management tool, diskpart commands, Free Partition Magic like MiniTool Partition Wizard, and others can help to create partition.
If the drive is not new and contains. Data you want to ever see again DO NOT repatriation it. Try a different port, the one you're trying may not meet power requirements for the drive leading windows to give you bad advice... you might still. Recover data after a reformat but the more you perform any writes to the drive the fewer files will remain recoverable
As we know, if you connect a new Toshiba external hard drive to your PC, your Windows may not recognize it because it has not been initialized. Open Disk Management. (Press Windows + R on your keyboard to launch the Run dialog box. Type "diskmgmt.msc" into the box and press OK.)
Right click on the name portion of the disk entry, where it says Disk [#]. Select Initialise Disk from the right-click context menu. And then, you will be given detailed operating prompts. Just do as told.
Note: during the initialization process, you'll be prompted to choose whether you want to use a Master Boot Record (MBR) or a GUID Partition Table (GPT) for the partition style of your Toshiba external hard drive. Here, in my opinion, if the capacity of your Toshiba HDD is over 2TB, you had better choose GPT, for MBR can support up to 2TB disk.
If your Toshiba external hard drive has been partitioned with the wrong file system, you will also encounter the "external hard drive not recognized" issue. For instance, you may have formatted the drive with the ext4 file system from Linux or the HFS Plus file system from a Mac. Or, you drive file system is damaged and shows as RAW.
However, Windows cannot recognize these file systems, thus Windows cannot recognize your external hard drive.
First, recover important files from the external hard drive that is not detected by Windows. Second, reformat this drive with the newer NTFS file system or older FAT32 file system so Windows will be able to recognize it.
Avoid fat32 since it does not support file sizes greater than 4GB which will cause file corruption. These days a file that large is not remarkable. Conversely if you'll be using the drive with an android device it won't see NTFS. Choose and remember the limitations.
To guard against malware infections causing issues, first scan your computer, if clean scan the external drive.
Disable auto-execution for external USB then do the scan before attempts to back up or recover. You don't want to include any viruses. This step should occur as soon as the drive is visible to Windows.
17 farklı kişi bu kılavuzu tamamladı.
12Kılavuz Yorumları
All of the solutions revolve around the fact that diskmgmt.msc registered the device. My computer detected there was something in the USB port, just didn’t know what it was.
mine kept coming up with “redundant cycle error” and it wont do anything
My drive doesn’t show up in any of these solutions. The only place it shows up is I. Computer Management>Disc Drives.
Great little series of potential fixes (and if someone can read, they don’t need pics), but unfortunately, like some others, my brand new drive doesn’t show up anywhere at all. It was formatted on an 8.1 machine using Macrium with which I cloned a drive, which I am fairly certain was an NTFS type format. But, nada. Win 10 sucks again.
Thanks very much
Reassigning the drive letter fixed my issue. Many thanks!!
Comment faire si les anciens HD issuent de XP n’apparait pas SUR Windows 10?
I would not say this guide is outdated, the content is still germane and valid.
What about the FIX for if the drive is not detected in Disk Management either?
no me deja formatear el disco, ni con cmd
conecte un disco externo a un televisor para reproducir unas fotos luego cuando lo conecte a la laptop no funcionaba marca un error que dice que no se puede obtener acceso; acceso denegado, probe con las soluciones que salen en esta pagina pero no funciona a alguien le paso, como logro solucionarlo?
If you have the device not recognized, warning triangle icon right click it, select uninstall device then select Rescan from the drop-down menu above. If the drive is still not recognized try restarting your computer with the drive plugged in rather than attaching it after booting oddly, this sometimes works. Do try the drive in all your available ports, power issues port configurations may be the problem
Juan Garcia - Yanıt
Other things to try: NOT using a USB hub. A different cable. A different computer.
Juan Garcia - Yanıt
