Ana içeriğe geç
Fixing Gelled Diesel in a 2008 Ford F-250
Jake Davis
Jake Davis ve başka bir katkıda bulunan
En son June 22, 2021 tarihinde güncellendi
2 - 3 saat
Kolay
Trucks that are left in freezing weather can experience diesel gelling which causes the vehicle to not turn on. This repair will help as a guide to melt the gelled diesel back to a liquid and help the truck start properly. The vehicle that is used in this guide will be a 2008 Ford-250 truck, but the same concepts apply to all diesel vehicles.
  1. Fixing Gelled Diesel in a 2008 Ford F-250, Fixing Gelled Diesel in a 2008 Ford F-250: adım 1, 2 resimden 1. Fixing Gelled Diesel in a 2008 Ford F-250, Fixing Gelled Diesel in a 2008 Ford F-250: adım 1, 2 resimden 2.
    • Use an extension cord and plug it into the engine block heater which is located on the front bumper of the truck.
    • This process is used to help heat the truck.
  2. Fixing Gelled Diesel in a 2008 Ford F-250: adım 2, 3 resimden 1. Fixing Gelled Diesel in a 2008 Ford F-250: adım 2, 3 resimden 2. Fixing Gelled Diesel in a 2008 Ford F-250: adım 2, 3 resimden 3.
    • Be sure to follow all of the instructions printed on your Gelled Diesel Additive.
    • Pour 16 ounces of Gelled Diesel Additive to every 20 gallons of fuel directly into the tank using the funnel as shown.
  3. Fixing Gelled Diesel in a 2008 Ford F-250: adım 3, 2 resimden 1. Fixing Gelled Diesel in a 2008 Ford F-250: adım 3, 2 resimden 2.
    • Pour a quarter of a tank worth of diesel into the tank.
    • More diesel in the tank gives you a greater chance of the truck starting in the freezing weather.
  4. Fixing Gelled Diesel in a 2008 Ford F-250: adım 4, 1 resimden 1.
    • Wait an hour for the Gelled Diesel Additive to activate. Then go inside the truck and try starting it by putting the key into the ignition.
  5. Fixing Gelled Diesel in a 2008 Ford F-250: adım 5, 1 resimden 1.
    • After starting the truck, move the vehicle into a garage where there is a greater chance of warmth.
  6. Fixing Gelled Diesel in a 2008 Ford F-250: adım 6, 2 resimden 1. Fixing Gelled Diesel in a 2008 Ford F-250: adım 6, 2 resimden 2.
    • Plug in your heat lamp and place the lamp under the truck, as this will also help heat the vehicle.
    • The heat lamp greatly increases the chance of the gelled diesel melting quicker.
Sonuç
Try to start your truck! If your vehicle still won’t start, try these steps again!
Jake Davis
133 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 590
