Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Using a large needle nose plier, take out the stoppers from each side of the axle.
Use the large needle nose pliers to pull out the locking pins from the holes in the axel to detach the axel from the cart's legs.
Repeat for both sides.
Carefully pull out the axle to detach it from the cart’s legs.
Slide off the first washer, the spring, and the second washer.
Take out the tattered wheel.
Repeat steps 4 and 5 for the second wheel.
Take one of the new wheels and slide it on one side of the axle.
Slide on the first washer, the spring, and then the second washer back on the axle.
Repeat steps 6 and 7 for the second wheel.
Carefully place the front wheel axle with the new wheels in the side holes of the cart’s legs.
Insert the locking pins in each hole at both ends of the axle until the pins are halfway in the hole.
Using the hammer, tap the pins until they are entirely inside the hole.
Lastly, push the stoppers in each hole of the cart's legs.
Using the hammer, tap them in place.
2 farklı kişi bu kılavuzu tamamladı.
