Ana içeriğe geç
Framework Desktop Power Button Board Replacement
Neye ihtiyacın var
    1. Framework Desktop Power Button Board Replacement, Power down your Desktop: adım 1, 3 resimden 1. Framework Desktop Power Button Board Replacement, Power down your Desktop: adım 1, 3 resimden 2. Framework Desktop Power Button Board Replacement, Power down your Desktop: adım 1, 3 resimden 3.
      • Before you begin repairs, shut down your Desktop from the operating system and unplug it.
      • Wait one minute before continuing to allow your Desktop to fully power down.
      • Make sure your Framework Desktop Screwdriver has the T5 Torx bit (labeled as T5) facing outwards. If it's not, pull the bit out and flip it.
      FixBot'a Sor
      Yorum Ekle
    1. Framework Desktop Power Button Board Replacement, Remove the Left Panel: adım 2, 3 resimden 1. Framework Desktop Power Button Board Replacement, Remove the Left Panel: adım 2, 3 resimden 2. Framework Desktop Power Button Board Replacement, Remove the Left Panel: adım 2, 3 resimden 3.
      • Use your fingers to grip the top of the Left Panel and slide it upward to release its clips.
      • Remove the Left Panel.
      FixBot'a Sor
      Yorum Ekle
    1. Framework Desktop Power Button Board Replacement, Remove the Right Panel: adım 3, 3 resimden 1. Framework Desktop Power Button Board Replacement, Remove the Right Panel: adım 3, 3 resimden 2. Framework Desktop Power Button Board Replacement, Remove the Right Panel: adım 3, 3 resimden 3.
      • Use your fingers to grip the top of the Right Panel and slide it upward to release its clips.
      • Remove the Right Panel.
      FixBot'a Sor
      Yorum Ekle
    1. Framework Desktop Power Button Board Replacement, Remove the Front Panel: adım 4, 3 resimden 1. Framework Desktop Power Button Board Replacement, Remove the Front Panel: adım 4, 3 resimden 2. Framework Desktop Power Button Board Replacement, Remove the Front Panel: adım 4, 3 resimden 3.
      • Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
      FixBot'a Sor
      Yorum Ekle
    2. Framework Desktop Power Button Board Replacement, Remove the top plate screws: adım 5, 2 resimden 1. Framework Desktop Power Button Board Replacement, Remove the top plate screws: adım 5, 2 resimden 2.
      • While holding the Desktop steady, use your Framework Desktop Screwdriver to remove the eight 4.0 mm‑long Phillips screws securing the top plate.
      FixBot'a Sor
      Yorum Ekle
    3. Framework Desktop Power Button Board Replacement, Remove the top plate: adım 6, 2 resimden 1. Framework Desktop Power Button Board Replacement, Remove the top plate: adım 6, 2 resimden 2.
      • Lift the top plate off the Desktop and remove it.
      FixBot'a Sor
      Yorum Ekle
    4. Framework Desktop Power Button Board Replacement, Reposition the Desktop: adım 7, 2 resimden 1. Framework Desktop Power Button Board Replacement, Reposition the Desktop: adım 7, 2 resimden 2.
      • Rotate the Desktop onto its right side so the Mainboard is facing upward.
      FixBot'a Sor
      Yorum Ekle
    5. Framework Desktop Power Button Board Replacement, Disconnect the power button: adım 8, 2 resimden 1. Framework Desktop Power Button Board Replacement, Disconnect the power button: adım 8, 2 resimden 2.
      • Use your fingers to lift the power button cable connector off its nine‑pronged socket on the Mainboard.
      FixBot'a Sor
      Yorum Ekle
    6. Framework Desktop Power Button Board Replacement, Reroute the power button cable: adım 9, 2 resimden 1. Framework Desktop Power Button Board Replacement, Reroute the power button cable: adım 9, 2 resimden 2.
      • Pull the power button cable out of its rubber clips in the chassis.
      FixBot'a Sor
      Yorum Ekle
    7. Framework Desktop Power Button Board Replacement, Reposition the Desktop: adım 10, 2 resimden 1. Framework Desktop Power Button Board Replacement, Reposition the Desktop: adım 10, 2 resimden 2.
      • Rotate the Desktop so it sits upright.
      FixBot'a Sor
      Yorum Ekle
    8. Framework Desktop Power Button Board Replacement, Remove the Power Button Board screws: adım 11, 2 resimden 1. Framework Desktop Power Button Board Replacement, Remove the Power Button Board screws: adım 11, 2 resimden 2.
      • Use your Framework Desktop Screwdriver to remove the two 4.5 mm‑long screws securing the Power Button Board.
      FixBot'a Sor
      Yorum Ekle
    9. Framework Desktop Power Button Board Replacement, Reposition the Power Button Board: adım 12, 2 resimden 1. Framework Desktop Power Button Board Replacement, Reposition the Power Button Board: adım 12, 2 resimden 2.
      • Use your finger to pull the Power Button Board off its alignment peg.
      FixBot'a Sor
      Yorum Ekle
    10. Framework Desktop Power Button Board Replacement, Remove the Power Button Board: adım 13, 3 resimden 1. Framework Desktop Power Button Board Replacement, Remove the Power Button Board: adım 13, 3 resimden 2. Framework Desktop Power Button Board Replacement, Remove the Power Button Board: adım 13, 3 resimden 3.
      • Pull the Power Button Board away from the Desktop, threading its cable through the chassis.
      FixBot'a Sor
      Yorum Ekle
    1. Framework Desktop Power Button Board Replacement, Disassembly complete: adım 14, 1 resimden 1.
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
      FixBot'a Sor
      Yorum Ekle
    1. Framework Desktop Power Button Board Replacement, Place the Power Button Board: adım 15, 3 resimden 1. Framework Desktop Power Button Board Replacement, Place the Power Button Board: adım 15, 3 resimden 2. Framework Desktop Power Button Board Replacement, Place the Power Button Board: adım 15, 3 resimden 3.
      • Insert the Power Button Board cable into the slot in the Desktop.
      • Grip the cable from the top of the Desktop and thread it through the chassis.
      FixBot'a Sor
      Yorum Ekle
    2. Framework Desktop Power Button Board Replacement, Reposition the Power Button Board: adım 16, 2 resimden 1. Framework Desktop Power Button Board Replacement, Reposition the Power Button Board: adım 16, 2 resimden 2.
      • Place the board into its slot in the Desktop so the alignment peg is threaded through its hole in the board.
      FixBot'a Sor
      Yorum Ekle
    3. Framework Desktop Power Button Board Replacement, Install the Power Button Board screws: adım 17, 2 resimden 1. Framework Desktop Power Button Board Replacement, Install the Power Button Board screws: adım 17, 2 resimden 2.
      • Use your Framework Desktop Screwdriver to install the two 4.5 mm‑long screws securing the Power Button Board.
      FixBot'a Sor
      Yorum Ekle
    4. Framework Desktop Power Button Board Replacement, Reposition the Desktop: adım 18, 2 resimden 1. Framework Desktop Power Button Board Replacement, Reposition the Desktop: adım 18, 2 resimden 2.
      FixBot'a Sor
      Yorum Ekle
    5. Framework Desktop Power Button Board Replacement, Reroute the power button cable: adım 19, 2 resimden 1. Framework Desktop Power Button Board Replacement, Reroute the power button cable: adım 19, 2 resimden 2.
      • Press the power button cable into its rubber clips in the chassis.
      FixBot'a Sor
      Yorum Ekle
    6. Framework Desktop Power Button Board Replacement, Connect the power button: adım 20, 2 resimden 1. Framework Desktop Power Button Board Replacement, Connect the power button: adım 20, 2 resimden 2.
      • Slide the power button cable over the nine-pronged connector on the Mainboard.
      FixBot'a Sor
      Yorum Ekle
    7. Framework Desktop Power Button Board Replacement, Reposition the Desktop: adım 21, 2 resimden 1. Framework Desktop Power Button Board Replacement, Reposition the Desktop: adım 21, 2 resimden 2.
      FixBot'a Sor
      Yorum Ekle
    8. Framework Desktop Power Button Board Replacement, Place the top plate: adım 22, 2 resimden 1. Framework Desktop Power Button Board Replacement, Place the top plate: adım 22, 2 resimden 2.
      • Place the top plate on top of the Desktop, making sure it slots into the chassis so the orange circles are visible.
      FixBot'a Sor
      Yorum Ekle
    9. Framework Desktop Power Button Board Replacement: adım 23, 2 resimden 1. Framework Desktop Power Button Board Replacement: adım 23, 2 resimden 2.
      • Make sure the matching screw hole on the top plate labeled "5/8" is slotted on the inside of the Chassis so that the orange circle is visible.
      FixBot'a Sor
      Yorum Ekle
    10. Framework Desktop Power Button Board Replacement, Install the top plate screws: adım 24, 2 resimden 1. Framework Desktop Power Button Board Replacement, Install the top plate screws: adım 24, 2 resimden 2.
      • While holding the Desktop steady, use your Framework Desktop Screwdriver to install the eight 4.0 mm‑long Phillips screws securing the top plate.
      FixBot'a Sor
      Yorum Ekle
    11. Framework Desktop Power Button Board Replacement, Install the Front Panel: adım 25, 3 resimden 1. Framework Desktop Power Button Board Replacement, Install the Front Panel: adım 25, 3 resimden 2. Framework Desktop Power Button Board Replacement, Install the Front Panel: adım 25, 3 resimden 3.
      • Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
      • Press the Front Panel flat to the chassis and let it align to the magnets.
      FixBot'a Sor
      Yorum Ekle
    1. Framework Desktop Power Button Board Replacement, Install the Right Panel: adım 26, 3 resimden 1. Framework Desktop Power Button Board Replacement, Install the Right Panel: adım 26, 3 resimden 2. Framework Desktop Power Button Board Replacement, Install the Right Panel: adım 26, 3 resimden 3.
      • Slide the Right Panel onto the right edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place.
      • There should be a small gap between the bottom of the Right Panel and the silver base.
      • Push the Right Panel towards the base of the computer to engage the clips.
      FixBot'a Sor
      Yorum Ekle
    1. Framework Desktop Power Button Board Replacement, Install the Left Panel: adım 27, 3 resimden 1. Framework Desktop Power Button Board Replacement, Install the Left Panel: adım 27, 3 resimden 2. Framework Desktop Power Button Board Replacement, Install the Left Panel: adım 27, 3 resimden 3.
      • Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place.
      • There should be a small gap between the bottom of the Left Panel and the silver base.
      • Push the Left Panel towards the base of the computer to close the gap and engage the clips.
      FixBot'a Sor
      Yorum Ekle
Sonuç
You finished fixing your Framework Desktop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
247.069 İtibar
1.203 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 57
Her zaman: 558
