Ana içeriğe geç
Framework Laptop 16" Graphics Module Fan Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Framework Laptop 16" Graphics Module Fan Replacement, Before you begin: adım 1, 2 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Before you begin: adım 1, 2 resimden 2.
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Framework Laptop 16" Graphics Module Fan Replacement, Unlock the Input Modules: adım 2, 3 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Unlock the Input Modules: adım 2, 3 resimden 2. Framework Laptop 16" Graphics Module Fan Replacement, Unlock the Input Modules: adım 2, 3 resimden 3.
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  3. Framework Laptop 16" Graphics Module Fan Replacement, Remove the touchpad spacers: adım 3, 3 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Remove the touchpad spacers: adım 3, 3 resimden 2. Framework Laptop 16" Graphics Module Fan Replacement, Remove the touchpad spacers: adım 3, 3 resimden 3.
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  4. Framework Laptop 16" Graphics Module Fan Replacement: adım 4, 1 resimden 1.
    • Repeat the same procedure for the other touchpad spacer.
  5. Framework Laptop 16" Graphics Module Fan Replacement, Remove the touchpad: adım 5, 3 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Remove the touchpad: adım 5, 3 resimden 2. Framework Laptop 16" Graphics Module Fan Replacement, Remove the touchpad: adım 5, 3 resimden 3.
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  6. Framework Laptop 16" Graphics Module Fan Replacement, Remove the keyboard: adım 6, 3 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Remove the keyboard: adım 6, 3 resimden 2. Framework Laptop 16" Graphics Module Fan Replacement, Remove the keyboard: adım 6, 3 resimden 3.
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
  7. Framework Laptop 16" Graphics Module Fan Replacement, Remove the numpad: adım 7, 3 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Remove the numpad: adım 7, 3 resimden 2. Framework Laptop 16" Graphics Module Fan Replacement, Remove the numpad: adım 7, 3 resimden 3.
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
  8. Framework Laptop 16" Graphics Module Fan Replacement, Lift the interposer door: adım 8, 2 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Lift the interposer door: adım 8, 2 resimden 2.
    • Lift the interposer door by its black pull tab and let it rest upright.
  9. Framework Laptop 16" Graphics Module Fan Replacement, Loosen the interposer screws: adım 9, 3 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Loosen the interposer screws: adım 9, 3 resimden 2. Framework Laptop 16" Graphics Module Fan Replacement, Loosen the interposer screws: adım 9, 3 resimden 3.
    • If you have the graphics module installed, your interposer will have four screws. Otherwise, you'll have three screws.
    • Lift the pull tab on the interposer and let it rest vertically to access all of its screws.
    • Use a T5 Torx screwdriver to loosen the three captive screws securing the interposer.
    • If you have the graphics module, use a T5 Torx screwdriver to loosen the four captive screws securing the interposer.
  10. Framework Laptop 16" Graphics Module Fan Replacement, Remove the interposer: adım 10, 2 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Remove the interposer: adım 10, 2 resimden 2.
    • Lift the interposer by its pull tab and remove it.
  11. Framework Laptop 16" Graphics Module Fan Replacement, Loosen the expansion bay screws: adım 11, 2 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Loosen the expansion bay screws: adım 11, 2 resimden 2.
    • Use a T5 Torx screwdriver to loosen the two captive screws securing the expansion bay.
    • Close the interposer door before continuing.
  12. Framework Laptop 16" Graphics Module Fan Replacement, Remove the expansion bay: adım 12, 3 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Remove the expansion bay: adım 12, 3 resimden 2. Framework Laptop 16" Graphics Module Fan Replacement, Remove the expansion bay: adım 12, 3 resimden 3.
    • Close your laptop and flip it over.
    • Slide the expansion bay out of the laptop and remove it.
    • The bay should slide out easily. If you feel any resistance, check that the screws holding it in place are fully loosened.
  13. Framework Laptop 16" Graphics Module Fan Replacement, Remove the graphics module cover screws: adım 13, 3 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Remove the graphics module cover screws: adım 13, 3 resimden 2. Framework Laptop 16" Graphics Module Fan Replacement, Remove the graphics module cover screws: adım 13, 3 resimden 3.
    • Flip over the graphics module so the fans are facing you.
    • Use a T5 Torx screwdriver to remove the four 3.6 mm‑long screws securing the graphics module cover:
    • Two screws on the flat surface of the module, next to the fans.
    • Two screws on the thin edge of the module, near the ends. You'll need to flip the module on its back edge to access them.
  14. Framework Laptop 16" Graphics Module Fan Replacement, Remove the graphics module cover: adım 14, 3 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Remove the graphics module cover: adım 14, 3 resimden 2. Framework Laptop 16" Graphics Module Fan Replacement, Remove the graphics module cover: adım 14, 3 resimden 3.
    • Use your fingers to lift the graphics module cover off the expansion bay and remove it.
  15. Framework Laptop 16" Graphics Module Fan Replacement, Disconnect the fan: adım 15, 2 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Disconnect the fan: adım 15, 2 resimden 2.
    • Use the flat end of a spudger, or a clean fingernail, to lift up and release the locking tab on the fan ZIF connector.
  16. Framework Laptop 16" Graphics Module Fan Replacement: adım 16, 2 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement: adım 16, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers, or your fingers, to grip the brown pull tab and slide the fan cable straight out of its socket.
  17. Framework Laptop 16" Graphics Module Fan Replacement, Loosen the fan screws: adım 17, 2 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Loosen the fan screws: adım 17, 2 resimden 2.
    • Use a T5 Torx screwdriver to loosen the four captive screws securing the fan.
  18. Framework Laptop 16" Graphics Module Fan Replacement, Remove the fan: adım 18, 3 resimden 1. Framework Laptop 16" Graphics Module Fan Replacement, Remove the fan: adım 18, 3 resimden 2. Framework Laptop 16" Graphics Module Fan Replacement, Remove the fan: adım 18, 3 resimden 3.
    • Use one hand to press the fan cable flat to the module.
    • Use your other hand to pull the fan out of its housing, making sure to thread the cable though its slot.
    • Remove the fan.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Bir başkası bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
220.385 İtibar
1.066 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
124 Üyeler
24.166 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 897
