Ana içeriğe geç
Fujifilm FinePix S8630 Speaker Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix S8630 Speaker Replacement, Battery Door: adım 1, 1 resimden 1.
    • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
  2. Fujifilm FinePix S8630 Speaker Replacement: adım 2, 1 resimden 1.
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
  3. Fujifilm FinePix S8630 Speaker Replacement: adım 3, 1 resimden 1.
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
  4. Fujifilm FinePix S8630 Speaker Replacement: adım 4, 2 resimden 1. Fujifilm FinePix S8630 Speaker Replacement: adım 4, 2 resimden 2.
    • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
    • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
  5. Fujifilm FinePix S8630 Speaker Replacement: adım 5, 1 resimden 1.
    • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
  6. Fujifilm FinePix S8630 Speaker Replacement: adım 6, 3 resimden 1. Fujifilm FinePix S8630 Speaker Replacement: adım 6, 3 resimden 2. Fujifilm FinePix S8630 Speaker Replacement: adım 6, 3 resimden 3.
    • Use the plastic opening tool to pry the back and front casings of the camera apart.
    • Once pried apart use your hands to pull off the back plate of the camera.
    • You will need to apply a little bit of force to remove the back plate.
  7. Fujifilm FinePix S8630 Speaker Replacement: adım 7, 3 resimden 1. Fujifilm FinePix S8630 Speaker Replacement: adım 7, 3 resimden 2. Fujifilm FinePix S8630 Speaker Replacement: adım 7, 3 resimden 3.
    • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
  8. Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: adım 8, 3 resimden 1. Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: adım 8, 3 resimden 2. Fujifilm FinePix S8630 Speaker Replacement, LCD Screen: adım 8, 3 resimden 3.
    • Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
  9. Fujifilm FinePix S8630 Speaker Replacement, Speaker: adım 9, 3 resimden 1. Fujifilm FinePix S8630 Speaker Replacement, Speaker: adım 9, 3 resimden 2. Fujifilm FinePix S8630 Speaker Replacement, Speaker: adım 9, 3 resimden 3.
    • Using your Philips head screwdriver remove the screws from the metal shield.
    • Remove the metal shield.
  10. Fujifilm FinePix S8630 Speaker Replacement: adım 10, 3 resimden 1. Fujifilm FinePix S8630 Speaker Replacement: adım 10, 3 resimden 2. Fujifilm FinePix S8630 Speaker Replacement: adım 10, 3 resimden 3.
    • Find the speaker and gently pull away from the motherboard. It is just on by an adhesive.
    • Identify where the speaker is connected to the motherboard and unsolder both of the connections,
    • Guide for Soldering: How To Solder and Desolder Connections
Sonuç
Colton Lancsarics
731 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-2, Sullivan Spring 2016 USF Tampa, Team 3-2, Sullivan Spring 2016 üyesi
USFT-SULLIVAN-S16S3G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 352
