Ana içeriğe geç
Fujifilm FinePix T500 Lens Gears Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix T500 Lens Gears Replacement, LCD Screen: adım 1, 3 resimden 1. Fujifilm FinePix T500 Lens Gears Replacement, LCD Screen: adım 1, 3 resimden 2. Fujifilm FinePix T500 Lens Gears Replacement, LCD Screen: adım 1, 3 resimden 3.
    • Unscrew the six 3.5mm Philips head from the outer casing.
  2. Fujifilm FinePix T500 Lens Gears Replacement: adım 2, 3 resimden 1. Fujifilm FinePix T500 Lens Gears Replacement: adım 2, 3 resimden 2. Fujifilm FinePix T500 Lens Gears Replacement: adım 2, 3 resimden 3.
    • Open the battery chamber and remove the battery.
    • Pry the front half of the casing from the camera.
    • Be careful that the sensor cover—the small piece of translucent plastic—doesn't fall out of place. Return it to its original location if it does.
  3. Fujifilm FinePix T500 Lens Gears Replacement: adım 3, 2 resimden 1. Fujifilm FinePix T500 Lens Gears Replacement: adım 3, 2 resimden 2.
    • Pry the back half of the casing from the camera.
    • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
  4. Fujifilm FinePix T500 Lens Gears Replacement: adım 4, 3 resimden 1. Fujifilm FinePix T500 Lens Gears Replacement: adım 4, 3 resimden 2. Fujifilm FinePix T500 Lens Gears Replacement: adım 4, 3 resimden 3.
    • Lift the LCD screen out of the camera.
    • There is a tab that keeps in place the ribbon that attaches the screen and motherboard. Lift this up using the spudger and disconnect the screen from the motherboard.
  5. Fujifilm FinePix T500 Lens Gears Replacement, Lens: adım 5, 1 resimden 1.
    • Unscrew the 3.5 mm Phillips head screw from the corner of the camera.
  6. Fujifilm FinePix T500 Lens Gears Replacement: adım 6, 3 resimden 1. Fujifilm FinePix T500 Lens Gears Replacement: adım 6, 3 resimden 2. Fujifilm FinePix T500 Lens Gears Replacement: adım 6, 3 resimden 3.
    • Pry the center casing off the camera. This is best done by separating the top and side sections individually.
  7. Fujifilm FinePix T500 Lens Gears Replacement: adım 7, 3 resimden 1. Fujifilm FinePix T500 Lens Gears Replacement: adım 7, 3 resimden 2. Fujifilm FinePix T500 Lens Gears Replacement: adım 7, 3 resimden 3.
    • Unscrew the two 3.5 mm Phillips head screws in the metal plate.
  8. Fujifilm FinePix T500 Lens Gears Replacement: adım 8, 2 resimden 1. Fujifilm FinePix T500 Lens Gears Replacement: adım 8, 2 resimden 2.
    • Pry the metal plate out using the spudger.
  9. Fujifilm FinePix T500 Lens Gears Replacement: adım 9, 3 resimden 1. Fujifilm FinePix T500 Lens Gears Replacement: adım 9, 3 resimden 2. Fujifilm FinePix T500 Lens Gears Replacement: adım 9, 3 resimden 3.
    • Peel back the strip of black tape to reveal a red and black wire.
    • Detach the orange ribbon by gently pulling on it.
    • Detach the golden ribbon by gently lifting it with the spudger.
  10. Fujifilm FinePix T500 Lens Gears Replacement: adım 10, 2 resimden 1. Fujifilm FinePix T500 Lens Gears Replacement: adım 10, 2 resimden 2.
    • The lens should now be free to simply be pushed out of its socket.
    • The black and red wires that were exposed previously may be in the way of removing the lens and may break. If they do, you will need to solder these wires back into place upon reassembly.
  11. Fujifilm FinePix T500 Lens Gears Replacement, Lens Gears: adım 11, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove four 3.5 mm screws from the corners of the internal plate.
  12. Fujifilm FinePix T500 Lens Gears Replacement: adım 12, 1 resimden 1.
    • Slide the rectangular plastic frame to the side. You'll find a spring attaches the frame to the rest of the lens casing.
    • Disconnect the plastic frame from the spring.
  13. Fujifilm FinePix T500 Lens Gears Replacement: adım 13, 3 resimden 1. Fujifilm FinePix T500 Lens Gears Replacement: adım 13, 3 resimden 2. Fujifilm FinePix T500 Lens Gears Replacement: adım 13, 3 resimden 3.
    • The white and the black gears of the lens unit are responsible for the lens movement.
    • Using tweezers, adjust and replace these gears as needed. The white gear should be integrated with the rest of the unit. The black gear should occupy the entirety of its cavity.
Sonuç
Brian Lasher
313 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 19-3, Blackwell Winter 2015 USF Tampa, Team 19-3, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S19G3
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
where can i get these gear’s? my camera is not opening its shutter, kindly let me know.
prabhu mandhar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 747
