Ana içeriğe geç
Fujifilm FinePix XP80 Speaker Replacement
Neye ihtiyacın var
  1. Fujifilm FinePix XP80 Speaker Replacement, Battery: adım 1, 3 resimden 1. Fujifilm FinePix XP80 Speaker Replacement, Battery: adım 1, 3 resimden 2. Fujifilm FinePix XP80 Speaker Replacement, Battery: adım 1, 3 resimden 3.
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80 Speaker Replacement: adım 2, 1 resimden 1.
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80 Speaker Replacement, Exterior Case: adım 3, 1 resimden 1.
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80 Speaker Replacement: adım 4, 1 resimden 1.
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80 Speaker Replacement: adım 5, 1 resimden 1.
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80 Speaker Replacement: adım 6, 1 resimden 1.
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80 Speaker Replacement: adım 7, 1 resimden 1.
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80 Speaker Replacement: adım 8, 1 resimden 1.
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80 Speaker Replacement: adım 9, 2 resimden 1. Fujifilm FinePix XP80 Speaker Replacement: adım 9, 2 resimden 2.
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80 Speaker Replacement, Interior Case: adım 10, 1 resimden 1.
    • Using the H1.3 hex head bit, remove the four screws on the front of the camera.
  11. Fujifilm FinePix XP80 Speaker Replacement: adım 11, 1 resimden 1.
    • Using the H1.3 hex head bit, remove the screw on the back of the camera.
  12. Fujifilm FinePix XP80 Speaker Replacement: adım 12, 1 resimden 1.
    • Open the battery compartment on the side of the camera.
    • Using your plastic opening tool, carefully pry the two clips apart as indicated in the photo.
  13. Fujifilm FinePix XP80 Speaker Replacement: adım 13, 3 resimden 1. Fujifilm FinePix XP80 Speaker Replacement: adım 13, 3 resimden 2. Fujifilm FinePix XP80 Speaker Replacement: adım 13, 3 resimden 3.
    • Unclip the front interior panel from the top, bottom and side of the camera.
  14. Fujifilm FinePix XP80 Speaker Replacement: adım 14, 1 resimden 1.
    • Gently open the camera, noting the presence of two orange tapes along one side that connect the motherboard to the LCD screen.
    • Open the camera like a book and lay both sides flat next to one another, leaving the orange tapes connected.
  15. Fujifilm FinePix XP80 Speaker Replacement, Speaker: adım 15, 2 resimden 1. Fujifilm FinePix XP80 Speaker Replacement, Speaker: adım 15, 2 resimden 2.
    • Carefully remove the black sticker covering the motherboard.
  16. Fujifilm FinePix XP80 Speaker Replacement: adım 16, 1 resimden 1.
    • Using a PH000 Phillips bit, remove the four screws shown.
  17. Fujifilm FinePix XP80 Speaker Replacement: adım 17, 1 resimden 1.
    • Using a plastic opening tool, carefully remove the lens housing to the left of the motherboard.
  18. Fujifilm FinePix XP80 Speaker Replacement: adım 18, 1 resimden 1.
    • Peel back the sticker on the side of the motherboard.
    • Using a PH000 Phillips bit, remove the screw.
  19. Fujifilm FinePix XP80 Speaker Replacement: adım 19, 2 resimden 1. Fujifilm FinePix XP80 Speaker Replacement: adım 19, 2 resimden 2.
    • Using a PH000 Phillips bit, remove the screw shown.
    • Unclip the three ribbon cables that are still attached to the motherboard.
    • Use the plastic opening tool to gently pry the motherboard loose.
    • Move the motherboard aside slightly to reveal the speaker, which is connected to the motherboard by red and black wires.
  20. Fujifilm FinePix XP80 Speaker Replacement: adım 20, 1 resimden 1.
    • Lift the motherboard out of the way, being careful of the speaker wires.
    • Carefully pry the speaker out of its slot in the case.
  21. Fujifilm FinePix XP80 Speaker Replacement: adım 21, 1 resimden 1.
Sonuç
Amanda Lewis
317 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Cagle Fall 2016 USF Tampa, Team 1-3, Cagle Fall 2016 üyesi
USFT-CAGLE-F16S1G3
5 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 308
