Ana içeriğe geç
Fujifilm Instax Mini 8 Capacitor Replacement
Neye ihtiyacın var
  1. Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: adım 1, 3 resimden 1. Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: adım 1, 3 resimden 2. Fujifilm Instax Mini 8 Capacitor Replacement, Capacitor: adım 1, 3 resimden 3.
    • First, push in the lens and remove the two AA batteries.
  2. Fujifilm Instax Mini 8 Capacitor Replacement: adım 2, 2 resimden 1. Fujifilm Instax Mini 8 Capacitor Replacement: adım 2, 2 resimden 2.
    • Open the rear compartment and remove the film cartridge.
  3. Fujifilm Instax Mini 8 Capacitor Replacement: adım 3, 3 resimden 1. Fujifilm Instax Mini 8 Capacitor Replacement: adım 3, 3 resimden 2. Fujifilm Instax Mini 8 Capacitor Replacement: adım 3, 3 resimden 3.
    • Remove screws from bottom of camera with a small #00 Phillips Screwdriver. Then remove screws around the camera. Additionally, there are two screws in the battery compartment which also need to be removed.
  4. Fujifilm Instax Mini 8 Capacitor Replacement: adım 4, 3 resimden 1. Fujifilm Instax Mini 8 Capacitor Replacement: adım 4, 3 resimden 2. Fujifilm Instax Mini 8 Capacitor Replacement: adım 4, 3 resimden 3.
    • Once all screws are removed, gently pry open the front casing with your hands or plastic opening tools carefully. Do note that there will be a spring that attaches the front casing and the main circuit board, so refrain from allowing excess tension on the spring.
  5. Fujifilm Instax Mini 8 Capacitor Replacement: adım 5, 3 resimden 1. Fujifilm Instax Mini 8 Capacitor Replacement: adım 5, 3 resimden 2. Fujifilm Instax Mini 8 Capacitor Replacement: adım 5, 3 resimden 3.
    • Locate the photo-flash capacitor, then find all the connecting wires to the motherboard and battery compartment. Take notes to which exact wires they are to limit mistakes.
  6. Fujifilm Instax Mini 8 Capacitor Replacement: adım 6, 3 resimden 1. Fujifilm Instax Mini 8 Capacitor Replacement: adım 6, 3 resimden 2. Fujifilm Instax Mini 8 Capacitor Replacement: adım 6, 3 resimden 3.
    • Carefully pry out the capacitor with a spudger or plastic opening tools.
  7. Fujifilm Instax Mini 8 Capacitor Replacement: adım 7, 3 resimden 1. Fujifilm Instax Mini 8 Capacitor Replacement: adım 7, 3 resimden 2. Fujifilm Instax Mini 8 Capacitor Replacement: adım 7, 3 resimden 3.
    • With a solder kit, heat the connecting solder points to open the connection, thus removing the connecting wires. There are many ways to do this, depending on the available tools on hand.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Boyang Wu
1.001 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-1, Meier Fall 2015 USF Tampa, Team 4-1, Meier Fall 2015 üyesi
USFT-MEIER-F15S4G1
4 Üyeler
26 adet Kılavuz yazıldı
3Kılavuz Yorumları
Hi There! I need a new capacitor for my daughter's Fuji Instax Mini 9. Do you supply? I am in South Africa.
Kuschi - Yanıt
Hi, any recommendations on where can find a shop in Kl Malaysia to fix my instax mini 8? Thanks in advance !
Miss.G - Yanıt
Bonjour, j'ai un instax mini 11 qui clignote orange rapidement.
Après divers manipulation de réinitialisation et de changement de pile pour des neuves rien y fait.
Est-ce que ça pourrait être un problème de condensateur qui empêche le flash de charger correctement ? Et mettrais donc l'appareil en erreur ?
Elise Tibbo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 32
Son 30 gün: 187
Her zaman: 26,491
