Ana içeriğe geç
Fujifilm X-M1 Back Case Replacement
Neye ihtiyacın var
  1. Fujifilm X-M1 Back Case Replacement, Battery: adım 1, 2 resimden 1. Fujifilm X-M1 Back Case Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the camera upside down to locate the battery compartment.
    • Slide the button up to open the compartment.
    • Slide the orange button up to release the battery.
    • The battery is not shown in these photos.
  2. Fujifilm X-M1 Back Case Replacement, Back Case: adım 2, 1 resimden 1.
    • Remove the six 2.5 mm Phillips screws from the bottom of the camera.
  3. Fujifilm X-M1 Back Case Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
    • Remove the 3.4 mm Phillips screw.
    • Remove the 3.7 mm screw.
  4. Fujifilm X-M1 Back Case Replacement: adım 4, 1 resimden 1.
    • Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
    • Remove the 3.2 mm Phillips screw.
    • Remove the 3.8 mm Phillips screw.
    • Remove the 2.8 mm Phillips screw.
  5. Fujifilm X-M1 Back Case Replacement: adım 5, 2 resimden 1. Fujifilm X-M1 Back Case Replacement: adım 5, 2 resimden 2.
    • Use tweezers to slide the metal shield straight out of the external flash mount.
  6. Fujifilm X-M1 Back Case Replacement: adım 6, 3 resimden 1. Fujifilm X-M1 Back Case Replacement: adım 6, 3 resimden 2. Fujifilm X-M1 Back Case Replacement: adım 6, 3 resimden 3.
    • Remove the four 4.6 mm Phillips screws from the external flash mount.
    • Use tweezers or two fingers to remove the mount clip.
  7. Fujifilm X-M1 Back Case Replacement: adım 7, 1 resimden 1.
    • Extend the LCD.
    • Remove the two black 4.3 mm Phillips screws from the back case.
  8. Fujifilm X-M1 Back Case Replacement: adım 8, 2 resimden 1. Fujifilm X-M1 Back Case Replacement: adım 8, 2 resimden 2.
    • Use two fingers to peel back and remove the black plastic cover from behind the LCD.
  9. Fujifilm X-M1 Back Case Replacement: adım 9, 3 resimden 1. Fujifilm X-M1 Back Case Replacement: adım 9, 3 resimden 2. Fujifilm X-M1 Back Case Replacement: adım 9, 3 resimden 3.
    • Slowly pull the back frame away from the camera.
    • Do not attempt to remove the frame, as it is attached to the camera by a ribbon cable.
    • Use tweezers to pull the white and blue ribbon cable out of the connector.
  10. Fujifilm X-M1 Back Case Replacement: adım 10, 1 resimden 1.
    • Slide the frame around the LCD to remove it from the camera.
  11. Fujifilm X-M1 Back Case Replacement: adım 11, 1 resimden 1.
    • Remove the two 2.6 mm Phillips screws from the right side of the metal frame.
  12. Fujifilm X-M1 Back Case Replacement: adım 12, 2 resimden 1. Fujifilm X-M1 Back Case Replacement: adım 12, 2 resimden 2.
    • Use tweezers to unhook the speaker near the left handgrip.
  13. Fujifilm X-M1 Back Case Replacement: adım 13, 2 resimden 1. Fujifilm X-M1 Back Case Replacement: adım 13, 2 resimden 2.
    • Slowly lift the metal frame away from the motherboard.
    • Do not attempt to remove the frame, as it is attached to the motherboard by a large ribbon cable.
    • Use tweezers to remove the plastic covering the motherboard.
  14. Fujifilm X-M1 Back Case Replacement: adım 14, 3 resimden 1. Fujifilm X-M1 Back Case Replacement: adım 14, 3 resimden 2. Fujifilm X-M1 Back Case Replacement: adım 14, 3 resimden 3.
    • To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
    • If the ribbon cable does not pop out on its own, use tweezers to pull it out of the connector.
    • Remove the back case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kelsea Weber
21.018 İtibar
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 1,767
