Ana içeriğe geç
Fujifilm X-M1 LCD Screen Replacement
Neye ihtiyacın var
    1. Fujifilm X-M1 LCD Screen Replacement, Battery: adım 1, 2 resimden 1. Fujifilm X-M1 LCD Screen Replacement, Battery: adım 1, 2 resimden 2.
      • Turn the camera upside down to locate the battery compartment.
      • Slide the button up to open the compartment.
      • Slide the orange button up to release the battery.
      • The battery is not shown in these photos.
      FixBot'a Sor
      Yorum Ekle
    1. Fujifilm X-M1 LCD Screen Replacement, Lens Assembly: adım 2, 3 resimden 1. Fujifilm X-M1 LCD Screen Replacement, Lens Assembly: adım 2, 3 resimden 2. Fujifilm X-M1 LCD Screen Replacement, Lens Assembly: adım 2, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Twist the lens cap to remove it from the camera.
      • Remove the six 6.5 mm Phillips screws from the front of the lens assembly.
      • Use tweezers to remove the top metal ring and the thin metal ring below it .
      FixBot'a Sor
      Yorum Ekle
    2. Fujifilm X-M1 LCD Screen Replacement: adım 3, 1 resimden 1.
      • Remove the four 4.3 mm Phillips screws inside the lens assembly.
      FixBot'a Sor
      Yorum Ekle
    1. Fujifilm X-M1 LCD Screen Replacement, Back Case: adım 4, 1 resimden 1.
      • Remove the six 2.5 mm Phillips screws from the bottom of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Fujifilm X-M1 LCD Screen Replacement: adım 5, 1 resimden 1.
      • Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
      • Remove the 3.4 mm Phillips screw.
      • Remove the 3.7 mm screw.
      FixBot'a Sor
      Yorum Ekle
    3. Fujifilm X-M1 LCD Screen Replacement: adım 6, 1 resimden 1.
      • Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
      • Remove the 3.2 mm Phillips screw.
      • Remove the 3.8 mm Phillips screw.
      • Remove the 2.8 mm Phillips screw.
      FixBot'a Sor
      Yorum Ekle
    4. Fujifilm X-M1 LCD Screen Replacement: adım 7, 2 resimden 1. Fujifilm X-M1 LCD Screen Replacement: adım 7, 2 resimden 2.
      • Use tweezers to slide the metal shield straight out of the external flash mount.
      FixBot'a Sor
      Yorum Ekle
    5. Fujifilm X-M1 LCD Screen Replacement: adım 8, 3 resimden 1. Fujifilm X-M1 LCD Screen Replacement: adım 8, 3 resimden 2. Fujifilm X-M1 LCD Screen Replacement: adım 8, 3 resimden 3.
      • Remove the four 4.6 mm Phillips screws from the external flash mount.
      • Use tweezers or two fingers to remove the mount clip.
      FixBot'a Sor
      Yorum Ekle
    6. Fujifilm X-M1 LCD Screen Replacement: adım 9, 1 resimden 1.
      • Extend the LCD.
      • Remove the two black 4.3 mm Phillips screws from the back case.
      FixBot'a Sor
      Yorum Ekle
    7. Fujifilm X-M1 LCD Screen Replacement: adım 10, 2 resimden 1. Fujifilm X-M1 LCD Screen Replacement: adım 10, 2 resimden 2.
      • Use two fingers to peel back and remove the black plastic cover from behind the LCD.
      FixBot'a Sor
      Yorum Ekle
    8. Fujifilm X-M1 LCD Screen Replacement: adım 11, 3 resimden 1. Fujifilm X-M1 LCD Screen Replacement: adım 11, 3 resimden 2. Fujifilm X-M1 LCD Screen Replacement: adım 11, 3 resimden 3.
      • Slowly pull the back frame away from the camera.
      • Do not attempt to remove the frame, as it is attached to the camera by a ribbon cable.
      • Use tweezers to pull the white and blue ribbon cable out of the connector.
      FixBot'a Sor
      Yorum Ekle
    9. Fujifilm X-M1 LCD Screen Replacement: adım 12, 1 resimden 1.
      • Slide the frame around the LCD to remove it from the camera.
      FixBot'a Sor
      Yorum Ekle
    10. Fujifilm X-M1 LCD Screen Replacement: adım 13, 1 resimden 1.
      • Remove the two 2.6 mm Phillips screws from the right side of the metal frame.
      FixBot'a Sor
      Yorum Ekle
    11. Fujifilm X-M1 LCD Screen Replacement: adım 14, 2 resimden 1. Fujifilm X-M1 LCD Screen Replacement: adım 14, 2 resimden 2.
      • Use tweezers to unhook the speaker near the left handgrip.
      FixBot'a Sor
      Yorum Ekle
    12. Fujifilm X-M1 LCD Screen Replacement: adım 15, 2 resimden 1. Fujifilm X-M1 LCD Screen Replacement: adım 15, 2 resimden 2.
      • Slowly lift the metal frame away from the motherboard.
      • Do not attempt to remove the frame, as it is attached to the motherboard by a large ribbon cable.
      • Use tweezers to remove the plastic covering the motherboard.
      FixBot'a Sor
      Yorum Ekle
    13. Fujifilm X-M1 LCD Screen Replacement: adım 16, 3 resimden 1. Fujifilm X-M1 LCD Screen Replacement: adım 16, 3 resimden 2. Fujifilm X-M1 LCD Screen Replacement: adım 16, 3 resimden 3.
      • To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
      • If the ribbon cable does not pop out on its own, use tweezers to pull it out of the connector.
      • Remove the back case.
      FixBot'a Sor
      Yorum Ekle
    1. Fujifilm X-M1 LCD Screen Replacement, LCD Screen: adım 17, 2 resimden 1. Fujifilm X-M1 LCD Screen Replacement, LCD Screen: adım 17, 2 resimden 2.
      • Remove the four 2.6 mm Phillips screws from the LCD hinges.
      • Tilt the LCD away from the metal frame.
      • Do not attempt to remove the LCD, as it is attached to the metal frame by a ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    2. Fujifilm X-M1 LCD Screen Replacement: adım 18, 2 resimden 1. Fujifilm X-M1 LCD Screen Replacement: adım 18, 2 resimden 2.
      • Use two fingers to pull the ribbon through the hole in the metal frame.
      • Remove the LCD from the metal frame.
      FixBot'a Sor
      Yorum Ekle
    3. Fujifilm X-M1 LCD Screen Replacement: adım 19, 2 resimden 1. Fujifilm X-M1 LCD Screen Replacement: adım 19, 2 resimden 2.
      • Use the pointed end of a spudger to remove the ribbon cover on the back of the LCD.
      FixBot'a Sor
      Yorum Ekle
    4. Fujifilm X-M1 LCD Screen Replacement: adım 20, 2 resimden 1. Fujifilm X-M1 LCD Screen Replacement: adım 20, 2 resimden 2.
      • Remove the two 2.6 mm Phillips screws from the right hand side of the LCD screen.
      • Remove the two 2.6 mm Phillips screws from the left hand side of the LCD screen.
      FixBot'a Sor
      Yorum Ekle
    5. Fujifilm X-M1 LCD Screen Replacement: adım 21, 3 resimden 1. Fujifilm X-M1 LCD Screen Replacement: adım 21, 3 resimden 2. Fujifilm X-M1 LCD Screen Replacement: adım 21, 3 resimden 3.
      • Use a plastic opening tool to pry the LCD case open.
      • Once the case is open, pull the ribbon through the hole on the back case.
      FixBot'a Sor
      Yorum Ekle
    6. Fujifilm X-M1 LCD Screen Replacement: adım 22, 1 resimden 1.
      • Remove the LCD from the screen cover.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kelsea Weber
21.458 İtibar
32 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 23
Son 30 gün: 84
Her zaman: 6,416
