Ana içeriğe geç
GATEWAY NE56R09u RAM Replacement
joshua depina
joshua depina ve 4 diğer katkıda bulunanlar
En son July 14, 2020 tarihinde güncellendi
5 dakika
Orta
Daha İyi Resimler Gerekli
Öğrenci İş Başında
The purpose of the RAM are for quick and temporary memory slots, this model specifically has two RAM that are blue in color. Before attempting to do a replacement, make sure your device is powered off and make sure to read through the guide first before jumping straight into a repair. Safety is always first!
Neye ihtiyacın var
Aletler
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  1. GATEWAY NE56R09u RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Before doing anything, first make sure the laptop is turned off and flipped over. In this position your laptop's bottom side should be facing up.
  2. GATEWAY NE56R09u RAM Replacement: adım 2, 1 resimden 1.
    • Using a nylon spudger or your fingers, push down on the battery clip to release the battery.
  3. GATEWAY NE56R09u RAM Replacement: adım 3, 1 resimden 1.
    • Finally, remove the battery by detaching it from the laptop casing. Once removed, set the battery aside and insert the new battery.
  4. GATEWAY NE56R09u RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Locate the casing that protects the RAM modules, wireless card, and hard drive.
  5. GATEWAY NE56R09u RAM Replacement: adım 5, 1 resimden 1.
    • With the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the RAM modules.
  6. GATEWAY NE56R09u RAM Replacement: adım 6, 1 resimden 1.
    • On each RAM module there are two silver latches holding them in place
    • Release the latches to be able to remove the RAM module.
  7. GATEWAY NE56R09u RAM Replacement: adım 7, 1 resimden 1.
    • Remove the RAM modules from their respected slots.
Sonuç
To reassemble your device, please follow these instructions in reverse order.
joshua depina
401 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G1, Peak Spring 2019 UMass Dartmouth, Team S6-G1, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G1
2 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 246
