Ana içeriğe geç
GE Refrigerator Main Control Board Replacement
Neye ihtiyacın var
  1. GE Refrigerator Main Control Board Replacement, Unplug your refrigerator: adım 1, 1 resimden 1.
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. GE Refrigerator Main Control Board Replacement, Remove the main control board cover: adım 2, 3 resimden 1. GE Refrigerator Main Control Board Replacement, Remove the main control board cover: adım 2, 3 resimden 2. GE Refrigerator Main Control Board Replacement, Remove the main control board cover: adım 2, 3 resimden 3.
    • Use a 1/4" nut driver to remove the screws securing the main control board cover.
    • Remove the main control board cover.
  3. GE Refrigerator Main Control Board Replacement, Disconnect the main control board: adım 3, 3 resimden 1. GE Refrigerator Main Control Board Replacement, Disconnect the main control board: adım 3, 3 resimden 2. GE Refrigerator Main Control Board Replacement, Disconnect the main control board: adım 3, 3 resimden 3.
    • Note or take a photo of the position of all of the connectors
    • With your fingers, grasp each connector, squeeze any locking tabs, and pull all the connectors off the board.
  4. GE Refrigerator Main Control Board Replacement, Remove the main control board: adım 4, 3 resimden 1. GE Refrigerator Main Control Board Replacement, Remove the main control board: adım 4, 3 resimden 2. GE Refrigerator Main Control Board Replacement, Remove the main control board: adım 4, 3 resimden 3.
    • Using long nose pliers, squeeze the locking tabs on the mounting studs. While you do this, with your other hand pull the board gently outward so that the board won't slip back over a stud that has been released.
    • Lift the area of the board closest to the stud to free it from the mounting studs
    • Repeat this process of each mounting stud. until the board is free of each stud. Remove the board.
    • Try to work from one corner of the board down one side, then across. That will make it easier to maintain the gentle outward pressure and prevent the board from slipping back over the studs.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Bill Gilbert
38.507 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.649 adet Kılavuz yazıldı
1Rehber Yorum
Control board 245D1888G002 R57 light blink all the time
Freddie Mckinney - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 54
Her zaman: 793
