Ana içeriğe geç
GE Side-By-Side Refrigerator Evaporator Cover Replacement
Neye ihtiyacın var
  1. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Unplug your refrigerator: adım 1, 1 resimden 1.
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Remove ice bin: adım 2, 3 resimden 1. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Remove ice bin: adım 2, 3 resimden 2. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Remove ice bin: adım 2, 3 resimden 3.
    • Grasp the ice bin and lift it upward slightly.
    • Pull the bin out of the freezer compartment and remove it.
  3. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Remove ice maker cover: adım 3, 3 resimden 1. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Remove ice maker cover: adım 3, 3 resimden 2. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Remove ice maker cover: adım 3, 3 resimden 3.
    • Lift the front edge of the cover 1cm (1/2") and pull the cover out of the freezer compartment.
  4. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Unfasten ice maker: adım 4, 1 resimden 1.
    • Use a 1/4" nut driver to loosen or remove the two screws securing the ice maker in place.
  5. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Reposition the ice maker: adım 5, 3 resimden 1. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Reposition the ice maker: adım 5, 3 resimden 2. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Reposition the ice maker: adım 5, 3 resimden 3.
    • Lift the icemaker upward to allow the mounting keyholes to slip over the screw heads.
  6. GE Side-By-Side Refrigerator Evaporator Cover Replacement: adım 6, 2 resimden 1. GE Side-By-Side Refrigerator Evaporator Cover Replacement: adım 6, 2 resimden 2.
    • Reposition the ice maker to the lower right, below the auger motor.
    • You may be able to rest it on a lower shelf.
    • The ice maker is still connected to the electrical supply. Don't try to remove it yet.
  7. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Disconnect ice maker: adım 7, 3 resimden 1. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Disconnect ice maker: adım 7, 3 resimden 2. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Disconnect ice maker: adım 7, 3 resimden 3.
    • Disconnect ice maker plug by loosening the retainer clips by lifting them if possible and then pulling the plug out of the socket. The socket is shown with the plug removed.
    • This may take some force. You can try lifting the retainer clips with a small flat head screwdriver, but access is difficult.
    • Remove the ice maker from the freezer compartment.
  8. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Unfasten the ice auger motor: adım 8, 1 resimden 1.
    • Use a 1/4" nut driver to remove the two screws securing the ice auger motor to its support brackets.
  9. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Free the ice auger motor from its support brackets: adım 9, 3 resimden 1. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Free the ice auger motor from its support brackets: adım 9, 3 resimden 2. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Free the ice auger motor from its support brackets: adım 9, 3 resimden 3.
    • Lift the ice auger motor to the right to free it from the left hand support bracket.
    • Lower the ice auger motor to the left, forward and down to allow it to clear the right hand support bracket.
  10. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Reposition the ice auger motor assembly: adım 10, 3 resimden 1. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Reposition the ice auger motor assembly: adım 10, 3 resimden 2. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Reposition the ice auger motor assembly: adım 10, 3 resimden 3.
    • Lower the auger motor assembly so that you can access the electrical connection.
  11. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Disconnect and remove the ice auger motor assembly: adım 11, 3 resimden 1. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Disconnect and remove the ice auger motor assembly: adım 11, 3 resimden 2. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Disconnect and remove the ice auger motor assembly: adım 11, 3 resimden 3.
    • The ice auger motor connection is mounted at an angle.
    • Squeeze the locking tabs on the connector to release it from the socket and pull it out to disconnect it.
    • Remove the ice auger motor assembly.
  12. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Remove shelves.: adım 12, 2 resimden 1. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Remove shelves.: adım 12, 2 resimden 2.
    • Lift the right edge of the shelf to free it from the clips which secure it.
    • This may take a bit of force as the clips hold firmly
    • Once the shelf is lifted, move it to the right and free the tabs on the left edge.
    • Remove the shelf.
    • Repeat this for each of the freezer shelves.
  13. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Remove the light bulb: adım 13, 2 resimden 1. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Remove the light bulb: adım 13, 2 resimden 2.
    • Unscrew the light bulb and set it aside.
  14. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Remove the lower evaporator cover: adım 14, 1 resimden 1.
    • Use a #2 Phillips screwdriver to remove the retaining screws securing the lower evaporator cover.
  15. GE Side-By-Side Refrigerator Evaporator Cover Replacement: adım 15, 3 resimden 1. GE Side-By-Side Refrigerator Evaporator Cover Replacement: adım 15, 3 resimden 2. GE Side-By-Side Refrigerator Evaporator Cover Replacement: adım 15, 3 resimden 3.
    • Remove the lower evaporator cover by pulling it toward you and then rotating it so it will get past the shelf brackets.
  16. GE Side-By-Side Refrigerator Evaporator Cover Replacement, Remove the evaporator fan cover: adım 16, 1 resimden 1.
    • Use a 1/4" nut driver to remove the four screws securing the evaporator fan cover to the rear of the refrigerator.
  17. GE Side-By-Side Refrigerator Evaporator Cover Replacement: adım 17, 3 resimden 1. GE Side-By-Side Refrigerator Evaporator Cover Replacement: adım 17, 3 resimden 2. GE Side-By-Side Refrigerator Evaporator Cover Replacement: adım 17, 3 resimden 3.
    • Lift the evaporator fan cover upward to free it.
    • Pull the top of the evaporator fan cover forward.
  18. GE Side-By-Side Refrigerator Evaporator Cover Replacement: adım 18, 1 resimden 1.
    • Remove the evaporator fan cover.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
37.443 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.543 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 15
Her zaman: 98
