Ana içeriğe geç
Galaxy Book3 360 13" SSD Replacement
Neye ihtiyacın var
  1. Galaxy Book3 360 13" SSD Replacement, Remove the Screws: adım 1, 1 resimden 1.
    • Flip the laptop over and remove each rubber shoe
    • Use a Philips screwdriver to care fully remove each screw
  2. Galaxy Book3 360 13" SSD Replacement, Remove the Case: adım 2, 2 resimden 1. Galaxy Book3 360 13" SSD Replacement, Remove the Case: adım 2, 2 resimden 2.
    • After removing the screws carefully pry open the case starting on the top right hinge.
    • There is a clip in the center of the laptop , when the edges are completely removed lift carefully to unclip the center.
  3. Galaxy Book3 360 13" SSD Replacement, Replace the SSD: adım 3, 1 resimden 1.
    • Carefully remove the screw holding down the SSD.
    • Lift the SSD until it is at about a 10-degree angle and then slide it out of the socket.
    • Slide in your new SSD, and follow the previous steps in reverse.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Dan
4.484 İtibar
9 adet Kılavuz yazıldı
5Kılavuz Yorumları
Are you sure for the second slot it is 2280 and not 2230?
Jeremy Asher - Yanıt
How can I be sure for my NP750QFG that it's 2280 and not 2230?
Any advice?
Galaxy book 3 360 15.6" inch variant support Gen 3 NVMe 2280 type ssd like WD Black SN770
Biswajit Shial -
Mine is 15.6 size and it's for the second slot, the 13" I think didn't have a second slot.
How do I know i it's for 2230 or 2280?
I opened my Book3 Pro 360 5G and the SSD is covered by a metal shield. How do I remove this shield to gain access to the SSD and slot?
Lloyd Franklin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 78
Son 30 gün: 471
Her zaman: 12,746
