Ana içeriğe geç
Game Boy Advance Back Shell Replacement
Neye ihtiyacın var
  1. Game Boy Advance Back Shell Replacement, Prepare your Game Boy for disassembly: adım 1, 2 resimden 1. Game Boy Advance Back Shell Replacement, Prepare your Game Boy for disassembly: adım 1, 2 resimden 2.
    • Before working on your Game Boy, turn the power switch to the OFF position and unplug any cables.
    • If you have a game cartridge installed, remove it.
    • Since your Game Boy will be laying screen‑side down for most of your repair, consider placing it on a clean cloth for protection.
    FixBot'a Sor
    Yorum Ekle
  2. Game Boy Advance Back Shell Replacement, Remove the battery cover: adım 2, 3 resimden 1. Game Boy Advance Back Shell Replacement, Remove the battery cover: adım 2, 3 resimden 2. Game Boy Advance Back Shell Replacement, Remove the battery cover: adım 2, 3 resimden 3.
    • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
    • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
    FixBot'a Sor
    Yorum Ekle
  3. Game Boy Advance Back Shell Replacement, Remove the batteries: adım 3, 3 resimden 1. Game Boy Advance Back Shell Replacement, Remove the batteries: adım 3, 3 resimden 2. Game Boy Advance Back Shell Replacement, Remove the batteries: adım 3, 3 resimden 3.
    • Remove the two AA batteries.
    • If the metal terminals are corroded, follow this guide to clean them.
    • When installing batteries, use the diagram in the battery well to properly orient them.
    FixBot'a Sor
    Yorum Ekle
  4. Game Boy Advance Back Shell Replacement, Remove the back shell screws: adım 4, 2 resimden 1. Game Boy Advance Back Shell Replacement, Remove the back shell screws: adım 4, 2 resimden 2.
    • Remove the seven screws securing the back shell:
    • Six 9.4 mm‑long tri‑point Y0 screws
    • One 8.5 mm‑long JIS 1 screw
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
    FixBot'a Sor
    Yorum Ekle
  5. Game Boy Advance Back Shell Replacement, Remove the back shell: adım 5, 2 resimden 1. Game Boy Advance Back Shell Replacement, Remove the back shell: adım 5, 2 resimden 2.
    • Lift the back shell straight up and remove it.
    • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
5 farklı kişi bu kılavuzu tamamladı.
Spencer Day
194.423 İtibar
1.243 adet Kılavuz yazıldı
2Kılavuz Yorumları
Seeing the GBA-SP guide, could information here be added so we know which mm triwing screws the regular GBA backpanel uses?
rguich - Yanıt Paylaş
We've updated the guide, and it now includes the screw measurements.
Spencer Day - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 26
Son 30 gün: 118
Her zaman: 13,451
