Ana içeriğe geç
How to Clean Corroded Battery Terminals
Neye ihtiyacın var
  1. How to Clean Corroded Battery Terminals, Safety precautions: adım 1, 1 resimden 1.
    • Wear gloves to protect your hands from the corrosion—it's a skin irritant.
    • If your device still works, power it down completely before starting.
    FixBot'a Sor
    Yorum Ekle
  2. How to Clean Corroded Battery Terminals, Remove the batteries: adım 2, 3 resimden 1. How to Clean Corroded Battery Terminals, Remove the batteries: adım 2, 3 resimden 2. How to Clean Corroded Battery Terminals, Remove the batteries: adım 2, 3 resimden 3.
    • Remove the batteries from your device.
    • If there's a lot of corrosion, the batteries may be stuck in their recess. Don't try to force them out...unless you're a small, green, force-sensitive creature.
    • If any batteries are stuck, follow the next step as normal to clean around them.
    FixBot'a Sor
    Yorum Ekle
  3. How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: adım 3, 3 resimden 1. How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: adım 3, 3 resimden 2. How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Brush
    $2.99
    • Use a toothbrush or anti‑static brush to gently remove any bigger chunks of corrosion from the battery terminals and battery recess.
    • Use the point of a spudger to pick out any bits that are stuck.
    • Pick around the batteries, and not at the batteries themselves.
    • Flip your device over and gently shake out the loose corrosion and debris.
    • Dispose of the corrosion and debris in the trash.
    FixBot'a Sor
    Yorum Ekle
  4. How to Clean Corroded Battery Terminals, Remove any stuck batteries: adım 4, 2 resimden 1. How to Clean Corroded Battery Terminals, Remove any stuck batteries: adım 4, 2 resimden 2.
    • You should now be able to remove any batteries that were previously stuck.
    • Clean out the battery recess with a toothbrush.
    FixBot'a Sor
    Yorum Ekle
  5. How to Clean Corroded Battery Terminals, Clean the terminals: adım 5, 3 resimden 1. How to Clean Corroded Battery Terminals, Clean the terminals: adım 5, 3 resimden 2. How to Clean Corroded Battery Terminals, Clean the terminals: adım 5, 3 resimden 3.
    • Alkaline batteries contain a base, which is what corrosion is made of. An acid like white vinegar or lemon juice will neutralize this base.
    • Lightly dip a cotton swab in white vinegar or lemon juice.
    • Don't soak the cotton swab. Only use a small amount of liquid at a time.
    • Gently rub the battery terminals with the cotton swab to dissolve and remove the corrosion.
    • The corrosion may fizz and bubble. Don't worry, this is normal.
    • Continue this process until there's no corrosion on the terminals.
    FixBot'a Sor
    Yorum Ekle
  6. How to Clean Corroded Battery Terminals: adım 6, 3 resimden 1. How to Clean Corroded Battery Terminals: adım 6, 3 resimden 2. How to Clean Corroded Battery Terminals: adım 6, 3 resimden 3.
    Microfiber Cleaning Cloths
    $3.99
    • Isopropyl alcohol will remove any residue left from the previous step.
    • Lightly dip a cotton swab in highly-concentrated isopropyl alcohol (over 90%).
    • Gently rub the battery terminals with the cotton swap to remove any remaining residue from the previous step.
    • Wipe the residue away with a microfiber or lint-free cloth.
    • Repeat this process until the terminals are completely clean.
    • Wait two minutes to allow any residual alcohol to evaporate.
    FixBot'a Sor
    Yorum Ekle
  7. How to Clean Corroded Battery Terminals, Install new batteries: adım 7, 3 resimden 1. How to Clean Corroded Battery Terminals, Install new batteries: adım 7, 3 resimden 2. How to Clean Corroded Battery Terminals, Install new batteries: adım 7, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Cleaning didn’t go as planned? Ask our Answers community for help.
For other electronics skills, click here.
21 farklı kişi bu kılavuzu tamamladı.
Spencer Day
195.202 İtibar
1.243 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.617 adet Kılavuz yazıldı
2Kılavuz Yorumları
Good article, thanks.
MarkDownUnder - Yanıt Paylaş
Nice Article . Thanks Bro
TSM Tool - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 69
Son 7 gün: 551
Son 30 gün: 2,307
Her zaman: 69,491
