Ana içeriğe geç
Game Boy Advance On/Off Switch Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Game Boy Advance On/Off Switch Replacement, Remove the battery cover: adım 1, 3 resimden 1. Game Boy Advance On/Off Switch Replacement, Remove the battery cover: adım 1, 3 resimden 2. Game Boy Advance On/Off Switch Replacement, Remove the battery cover: adım 1, 3 resimden 3.
    • Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
    • During reassembly, insert the tabs on the bottom edge of the cover into their cutouts and press the cover into place.
    FixBot'a Sor
    Yorum Ekle
  2. Game Boy Advance On/Off Switch Replacement, Remove the batteries: adım 2, 3 resimden 1. Game Boy Advance On/Off Switch Replacement, Remove the batteries: adım 2, 3 resimden 2. Game Boy Advance On/Off Switch Replacement, Remove the batteries: adım 2, 3 resimden 3.
    • Remove the two AA batteries.
    • If the metal terminals are corroded, follow this guide to clean them.
    • When installing batteries, use the diagram in the battery well to properly orient them.
    FixBot'a Sor
    Yorum Ekle
  3. Game Boy Advance On/Off Switch Replacement, Remove the back shell screws: adım 3, 2 resimden 1. Game Boy Advance On/Off Switch Replacement, Remove the back shell screws: adım 3, 2 resimden 2.
    • Remove the seven screws securing the back shell:
    • Six 9.4 mm‑long tri‑point Y0 screws
    • One 8.5 mm‑long JIS 1 screw
    • You can try to use a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping screws. Push down firmly on the driver and twist slowly.
    FixBot'a Sor
    Yorum Ekle
  4. Game Boy Advance On/Off Switch Replacement, Remove the back shell: adım 4, 2 resimden 1. Game Boy Advance On/Off Switch Replacement, Remove the back shell: adım 4, 2 resimden 2.
    • Lift the back shell straight up and remove it.
    • During reassembly, squeeze the shell firmly around the edges and ensure the shoulder buttons and bumpers are properly seated with no large gaps. Gently test the buttons to make sure everything feels correct.
    FixBot'a Sor
    Yorum Ekle
  5. Game Boy Advance On/Off Switch Replacement, Remove Triggers: adım 5, 2 resimden 1. Game Boy Advance On/Off Switch Replacement, Remove Triggers: adım 5, 2 resimden 2.
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
    FixBot'a Sor
    Yorum Ekle
  6. Game Boy Advance On/Off Switch Replacement, Remove the On/Off Switch: adım 6, 1 resimden 1.
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Adam
907 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-29, Maness Winter 2010 Cal Poly, Team 16-29, Maness Winter 2010 üyesi
CPSU-MANESS-W10S16G29
5 Üyeler
81 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 63
Her zaman: 22,565
