Ana içeriğe geç
Game Boy Color Power LED Replacement
Neye ihtiyacın var
  1. Game Boy Color Power LED Replacement, Battery: adım 1, 2 resimden 1. Game Boy Color Power LED Replacement, Battery: adım 1, 2 resimden 2.
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Power LED Replacement: adım 2, 1 resimden 1.
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Power LED Replacement, Back Housing: adım 3, 1 resimden 1.
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Game Boy Color Power LED Replacement: adım 4, 2 resimden 1. Game Boy Color Power LED Replacement: adım 4, 2 resimden 2.
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Power LED Replacement, Motherboard: adım 5, 2 resimden 1. Game Boy Color Power LED Replacement, Motherboard: adım 5, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
  6. Game Boy Color Power LED Replacement: adım 6, 1 resimden 1.
    • Gently lift the motherboard from the front housing.
  7. Game Boy Color Power LED Replacement, Power LED: adım 7, 2 resimden 1. Game Boy Color Power LED Replacement, Power LED: adım 7, 2 resimden 2.
  8. Game Boy Color Power LED Replacement: adım 8, 1 resimden 1.
    • Insert new LED into the circuit board.
    • Make sure that the LED is in the correct orientation. The longer leg of the LED is the positive end, while the shorter leg is the negative end.
    • The positive lead should go through the hole closest to the edge of the circuit board.
  9. Game Boy Color Power LED Replacement: adım 9, 1 resimden 1.
    • Solder the leads of the new LED to the circuit board.
  10. Game Boy Color Power LED Replacement: adım 10, 1 resimden 1.
    • Cut the excess ends of the LED legs using the wire cutters.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Alex Wu
1.446 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-47, Regan Winter 2013 Cal Poly, Team 19-47, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G47
4 Üyeler
56 adet Kılavuz yazıldı
6 Yorum
what is the brass color looking thing under the soldering iron in step 7?
Soul Divide - Yanıt
That's called 'Desoldering Braid', it sucks up solder like a wick
John Smith -
and what kind of LED are you using to replace?
Soul Divide - Yanıt
This was great! Exactly what I needed with this. My GBC is looking good as new now!
Erick - Yanıt
Bw sure to research what LED colors work best. You often need to remove a resistor adjacent to the diode to allow for the colors white/blue/purple.
Evan Wilgosh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 33
Son 30 gün: 157
Her zaman: 17,505
