Ana içeriğe geç
Game Boy Screen Replacement
Neye ihtiyacın var
  1. Game Boy Screen Replacement, Batteries: adım 1, 2 resimden 1. Game Boy Screen Replacement, Batteries: adım 1, 2 resimden 2.
    • Switch your Game Boy off and remove the cartridge.
    FixBot'a Sor
    Yorum Ekle
  2. Game Boy Screen Replacement: adım 2, 3 resimden 1. Game Boy Screen Replacement: adım 2, 3 resimden 2. Game Boy Screen Replacement: adım 2, 3 resimden 3.
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
    FixBot'a Sor
    Yorum Ekle
  3. Game Boy Screen Replacement: adım 3, 2 resimden 1. Game Boy Screen Replacement: adım 3, 2 resimden 2.
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
    FixBot'a Sor
    Yorum Ekle
  4. Game Boy Screen Replacement, Outer Case: adım 4, 1 resimden 1.
    • Remove the six Triwing screws from the back of the device.
    FixBot'a Sor
    Yorum Ekle
  5. Game Boy Screen Replacement: adım 5, 1 resimden 1.
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
    FixBot'a Sor
    Yorum Ekle
  6. Game Boy Screen Replacement: adım 6, 1 resimden 1.
    • Slide the front side of the casing down to expose the ribbon cable connector.
    FixBot'a Sor
    Yorum Ekle
  7. Game Boy Screen Replacement: adım 7, 1 resimden 1.
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
    FixBot'a Sor
    Yorum Ekle
  8. Game Boy Screen Replacement, Screen: adım 8, 1 resimden 1.
    • Remove the ten screws that connect the circuit board to the outer case.
    FixBot'a Sor
    Yorum Ekle
  9. Game Boy Screen Replacement: adım 9, 2 resimden 1. Game Boy Screen Replacement: adım 9, 2 resimden 2.
    • Remove the circuit board from the outer case using a plastic opening tool.
    • Take care to gently pry around the entire outside edge of the circuit board until you can easily remove the board without force.
    FixBot'a Sor
    Yorum Ekle
  10. Game Boy Screen Replacement: adım 10, 1 resimden 1.
    • Disengage the the three plastic clips that secure the screen to the circuit board.
    FixBot'a Sor
    Yorum Ekle
  11. Game Boy Screen Replacement: adım 11, 3 resimden 1. Game Boy Screen Replacement: adım 11, 3 resimden 2. Game Boy Screen Replacement: adım 11, 3 resimden 3.
    • Flip the circuit board over revealing the device screen.
    • Remove the two screws connecting the screen and the circuit board.
    FixBot'a Sor
    Yorum Ekle
    • Follow the video instructions to desolder the display connectors and replace your screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
50 farklı kişi bu kılavuzu tamamladı.
Andrew Tramposch
2.378 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-2, Johann Summer 2010 Cal Poly, Team 3-2, Johann Summer 2010 üyesi
CPSU-JOHANN-R10S3G2
3 Üyeler
40 adet Kılavuz yazıldı
14Kılavuz Yorumları
What kind of lcd screen or where can I find one that isn't off of another dmg-01 gameboy?
Floyd Odom - Yanıt Paylaş
I was wondering the same. Maybe ebay or Amazon.
Joshua Graham - Yanıt Paylaş
Replacement reflective LCDs are not possible to find. You can either purchase a screen salvaged from an old DMG, or get a brand new backlit LCD replacement.
mars - Yanıt Paylaş
What about the new display? Where to get it?
No spare part necessary should be replaced with a link where to buy a new one.
Helmut Kohli - Yanıt Paylaş
You can’t buy a new replacement screen unfortunately. Not only is it very difficult to remove the screen, it’s impossible to buy a replacement. They’d be better showing us how to fix a screen. There’s plenty of videos on YT showing how to fix blank vertical line but hardly any on how to fix horizontal lines, and the ones that do don’t work very well.
Firegoose - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 45
Son 7 gün: 336
Son 30 gün: 1,523
Her zaman: 179,620
